| Ignition switch/steering lock. Anyone else had their ignition switch jammed making inserting the key almost impossible? Also steering lock failed to come on when the key was removed. Was told by dealer that unless the car was brought in by the breakdown guys it would be three weeks before thay can look at it due to recalls. This was done eventually and now I have been told two weeks minimum for a new barrel to arrive from Germany! Just when i thought things were improving....... Oh and not impressed by a five hour+ breakdown responce and four further hours for the tow truck. |
| If you cannot turn the key in the ignition when the steering wheel is locked, I usually just turn the wheel abit back and forth till she goes. Also, the steering wheel must be faced in perfect position to enable its locking abilites. If the wheels are turned, the steering wheel won't lock. |
| I had my key jam IN the barrel (sept build). I noticed the barrel feeling a bit sticky a day or so before it jammed. I also had to wait over a week for a new assembly. The cause?...probably poor quality component. No problems since. |
| Convenience Opening Mode (lock switch) | RobbieK | First Generation Faults & Fixes | 8 | Nov 25th, 2005 07:27 AM |
| Unlock/Lock Toggle Switch (neat) | DEVO | General Discussion | 0 | Nov 21st, 2005 06:30 PM |
| Door lock Micro-switch | Poggy | First Generation Faults & Fixes | 0 | Mar 8th, 2005 12:54 PM |
| Toggle Switch Ignition Start | Nicholasp27 | First Generation Interior & Ice | 3 | Sep 10th, 2004 07:49 AM |
| What Steering Lock? | mepgcmm | General Discussion | 2 | Aug 11th, 2003 03:16 AM |
