passenger seat belt tensioners error - MINI Cooper Forum
post #1 of 9 (permalink) Old May 21st, 2014, 10:44 PM Thread Starter
Local Time: 01:49 PM
England passenger seat belt tensioners error
Hi, I've just checked for faults using a cheap cable off eBay and program called INPA this is wat I've got (had to translate via google )
ignition circuit zk2 / passenger seat belt tensioners error aktwell available resistant to large error not sporadically
Any ideas? Is it part of the common fault I've read about?
Nick
mininut1971 is offline
post #2 of 9 (permalink) Old May 22nd, 2014, 09:56 AM
Local Time: 12:49 PM
Hi ya
What mini do you have, from the sounds of it gen 1
Have you cleared the fault to see if it reappears.
You will most probably find if you clear the fault and the code comes back it's the connectors under the passenger seat.
Disconnect your battery first neg then poss leave it for 5 min
Disconnect the connectors under the seat check the wiring and connector are ok,reconnect them. then reconnect the battery poss then neg.
See if the code is present.
Have you got the dis software
marque is offline
post #3 of 9 (permalink) Old May 22nd, 2014, 10:25 AM Thread Starter
Originally Posted by marque View Post
Hi ya
Yeah it's Gen 1 2002 cooper, not sure what DIS software is tho, complete newbie to bmw mini as have never owned one.
Nick
post #4 of 9 (permalink) Old May 22nd, 2014, 10:27 AM Thread Starter
Originally Posted by ClairRichmond12 View Post
Nice Post!!!
Thanks (although I'm not sure if your being serious or sarcastic ) but thanks anyway
Nick
post #5 of 9 (permalink) Old May 22nd, 2014, 01:47 PM
Hi ya
No problem everyone has to start somewhere I was that person once. Lots of guys helped me :-)
When you got the lead from ebay what software came with it was it like this
BMW Diagnostic Software Cable lead Ediabas Inpa DIS SSS OBD lead | eBay
The DIS software is bmw's diagnostic tool, inpa is a early version and very basic diagnostic tool
I find DIS a lot easier to use and much better to trace faults with.
Have a look on youtube there are some vids on it.
Hope this helps
marque is offline
post #6 of 9 (permalink) Old May 22nd, 2014, 01:57 PM Thread Starter
Hi ya
Hope this helps
Not that seller but pretty much that cable and most of that software sounds familiar
This was wat it had
EDIABAS - INPA - NCS EXPERT- DIS v44 & v57 SSS/PROGMAN & with NAVCODER
post #7 of 9 (permalink) Old May 22nd, 2014, 02:35 PM
Cool good get the DIS loaded up its is much better to use.
It has more functions and easier to understand once you get used to it. The main thing is don't read to much in to the fault codes to start off with.
If you have a codes clear them to start with, then see if it returns then follow it throw.
or you will end up chasing something that is not there
Hope thus helps
marque is offline
post #8 of 9 (permalink) Old May 22nd, 2014, 02:38 PM Thread Starter
Hope thus helps
Yeah cleared code and it instantly returned did it a few times just to make sure.
post #9 of 9 (permalink) Old May 22nd, 2014, 02:46 PM
Ok
Sounds like the connector under the passengers seat you will have to have a good look at the wiring and plugs.
Also check the wire from the seat belt tensioner to the plug I have seen it where the wire gets damaged on the seat slider rail.
Hope this helps
marque is offline
Passenger seat mechanism different to drivers? Bossworld Second Generation Interior & Ice 6 Aug 12th, 2015 05:57 PM
Alternator fitting and serpentine belt Mini One 1.4D captainflak Welcome New Members 0 Jan 6th, 2014 04:06 PM
Wet rear seat belt! Hollywood First Generation Faults & Fixes 3 Oct 25th, 2013 11:52 AM
Passenger Seat Belt 01sturner General Discussion 1 Feb 2nd, 2013 12:57 PM
Passenger seat belt jamming in heat jbgg First Generation Interior & Ice 0 Aug 20th, 2012 06:38 PM
