Bizarre Horn problem. - MINI Cooper Forum
post #1 of 2 (permalink) Old May 23rd, 2014, 01:25 PM Thread Starter
Local Time: 12:28 AM
Hello guys,
I really need your help, I have spent too much money and the horn is still not fixed.
Basically the horn buttons don't work, so we changed the fuses still nothing, so we changed the actual horns as we thought they may be broke so we ordered new ones but still nothing. So then I bought a new rotary wheel for the steering wheel, but still nothing. We thought due to the age the fuse box may have broke or something bizarre like that so I ordered a new fuse box with all fuses etc... still nothing.. at this point we tested the wires, if we squashed one of the relays or the fuse the horn will go off, so the fuses and horn its self works fine except the buttons. So we tested the wires coming off the steering wheel and they were giving signs it was working so we tested the cables on the rotary wheel while plugged in, but they weren't giving any signs so at this point we thought we ordered a broken rotary wheel so we bought another one... but still it doesn't work.
Please help, i dont know what else to try i am getting fed up.
Thank you.
acid2k1 is offline
post #2 of 2 (permalink) Old May 23rd, 2014, 05:57 PM
Local Time: 01:28 AM
Quoted: 53 Post(s)
As youve tested or renewed everything else it sounds like an earthing fault??
Find the earthing point for the horns, and check its clean and secure, on the Gen 2 models its somewhere near the back of the offside headlight.
Yours is a Gen 1 though, might be in a similar area?
The Nun is offline
Tags: , , ,
2005 Mini Cooper S - No start problem Wintersroadshow First Generation Faults & Fixes 2 Mar 21st, 2014 02:58 PM
Intermittent sound problem with IPOD and AUX inputs dsmith Second Generation Interior & Ice 3 Jan 22nd, 2014 08:30 AM
Horn Sounds on its own. Triumph fan First Generation Faults & Fixes 2 Jun 3rd, 2013 12:21 PM
Mini problem - please help!! HelpMe General Discussion 13 Jan 18th, 2013 09:00 PM
