Mini Cooper s won't start - MINI Cooper Forum
post #1 of 5 (permalink) Old May 25th, 2014, 07:45 AM Thread Starter
Local Time: 11:47 AM
Hi have an intermittent start issue , insert key and turn ignition on all lights and dash come on fine but when you turn key to start you get nothing , the strange thing seems to be if I wiggle the key then try it again it then starts, any ideas ?
Have tried spare key get the exact same wouldn't have thought its the starter either as there are no clicks just acts like the battery is dead or a bad connection with the key sum how
z3mcoupe999 is offline
post #2 of 5 (permalink) Old May 25th, 2014, 07:53 AM
Quoted: 53 Post(s)
Ignition switch wearing out? they do if you use them.
The Nun is offline
post #3 of 5 (permalink) Old May 25th, 2014, 08:50 AM Thread Starter
Is the ignition switch sumthing that's easy to change on a mini
post #4 of 5 (permalink) Old May 31st, 2014, 10:50 PM
Local Time: 10:47 AM
techlab2k is offline
post #5 of 5 (permalink) Old Jun 1st, 2014, 02:49 AM
Local Time: 08:47 PM
Quoted: 166 Post(s)
Australia Male
Garage
The ignition switch has an EPROM and induction coil inside, this checks the key and communicates with the EMS and works off a rolling code to unlock the immobiliser. If no matching code can be found, it wont send a signal to the starter motor. If all other options have been checked (starter motor terminals etc) then its likely a fault with the ignition switch.
Milpol is offline
R56 Mini Cooper Erratic surging at idle from cold start Norfolk-Mini Second Generation Faults & Fixes 7 Mar 23rd, 2016 01:42 AM
2014 MINI Cooper Hardtop Revealed AutoGuide.com MINI News 15 Apr 23rd, 2015 03:15 PM
New 14 plate Mini Cooper SD Coupe Nightmare Kickboxkel Welcome New Members 7 Apr 4th, 2015 12:33 PM
Mini Cooper S Seat Heater Fire Paul.Armstrong First Generation Faults & Fixes 0 Apr 29th, 2014 02:08 PM
Automatic 2003 Mini Cooper wouldn't start and codes P1698 & P1787 were shown. Tyna Welcome New Members 2 Nov 12th, 2013 05:47 PM
