2005 Cooper S Oil Leak - Travels the length of the car? - MINI Cooper Forum
post #1 of 2 (permalink) Old Jun 2nd, 2014, 03:04 AM Thread Starter
Local Time: 06:30 PM
Canada
As described in the title, I appear to have a rather aggressive oil leak. First thoughts were the front crankcase seal, which involved removing the crankcase pulley (harmonic damper?).
Replaced that, but found it suspicious at the lack of oil inside the pulley itself for this to be the issue. Cleaned up the car as best as I can, in an effort to now retrace a leak.
What else leaks from the front that could travel such a way? It's mainly concentrated on the crankcase side of the engine, but my wishbone is getting coated too. Any help would be most appreciated.
Thank you in advance.
Apprentice is offline
post #2 of 2 (permalink) Old Jun 2nd, 2014, 06:58 AM
Local Time: 10:30 PM
Quoted: 53 Post(s)
Oil can be blown out at any seal or gasket if the engine crankcase breather system isnt clear, the pressure will find the weakest point and get out from there taking oil with it
Check the engines breather hoses are all clear and not deteriorated and maybe collapsed inside?
Excess crankcase pressure can be caused by a worn engine too with combustion gasses getting by the rings.
If you cant see directly where the leak is coming from, clean the underside down as best you can, or steam clean it, and park the car on a sheet of cardboard after a run to get an idea where the drips coming from.
The Nun is offline
MCS Engine noise when cold CBCooper Second Generation Faults & Fixes 2349 Mar 30th, 2016 09:09 PM
New 14 plate Mini Cooper SD Coupe Nightmare Kickboxkel Welcome New Members 7 Apr 4th, 2015 12:33 PM
2006 Mini Cooper S, oil leak UKGray First Generation MINI Cooper 6 Jan 19th, 2014 10:01 PM
Low Oil Pressure - Filter Debris in Oil System??!! MissMac General Discussion 5 Apr 1st, 2013 10:23 AM
URGENT - HELP/ADVICE NEEDED FOR R56 Mini Cooper S 2007 LadyUK Second Generation MINI Cooper S 18 Oct 23rd, 2012 06:29 PM
