Broken Dipstick in guide tube cheap fix - MINI Cooper Forum
post #1 of 4 (permalink) Old Jun 4th, 2014, 12:45 PM Thread Starter
Local Time: 04:05 PM
United Kingdom View nickw's Classified Ads
Hi, I thought I would share my experience with regards retrieving a broken dipstick from the guide tube.
I was checking my oil even know I knew the dipstick was weakened due to its poor design I continued to use it and the inevitable happened and it broke in my hand leaving 3/4 of it in the guide tube.
I took my mini to 2 garage who attempted to remove using long nose pliers but the pliers closed before you could even get a grip on the remaining dipstick. So I was left with a dilema remove the guide tube or remove the sump both jobs were quoted to me at around 300-400. Of course I said no and so went about trying to think of a way to remove it myself. First research the internet and I found that a cheap grabbing tool could work and has worked in the past, however very time consuming and you need the paitence of a saint. So my method involved a pair of long industrial tweezers and a resin glue ( see photo).
At first I used the tweezers which are narrower than pliers to inch the dipstick up he tube this took about 40 attemps to move it about an inch, then I applied a strong adhesive resin to the inside of the tweezers, inserted the tweezers into the guide tube onto either of the dipstick, waited 5 mins until it set and hey presto the dipstick came flying out no problems.
In all the whole thing took about 1hour and most importantly saved me 330-400 from the robbing garages.
I hope this helps someone as it could save you alot of time and money.
Nick
nickw is offline
The Following 2 Users Say Thank You to nickw For This Useful Post:
post #2 of 4 (permalink) Old Jun 4th, 2014, 10:56 PM
cjm
cjm's Avatar
Quoted: 11 Post(s)
United Kingdom Male View cjm's Classified Ads
A brilliant bit of out-of-the-box thinking...well done!
(Mini Service Agents please take notice.)
cjm is offline
post #3 of 4 (permalink) Old Jun 4th, 2014, 11:20 PM
mab01uk's Avatar
Local Time: 03:05 PM
Quoted: 1 Post(s)
Well done, thanks for sharing!
mab01uk is offline
post #4 of 4 (permalink) Old Jun 5th, 2014, 04:40 PM Thread Starter
No problems at all I hope it helps someone, as I have read that some individuals have paid the 300 plus to remove the sump when you dont need to. In most of the cases I have seen the dipstick breaks at the same point so it can be done and saves you alot of money.
Nick
nickw is offline
