Lower front arm - MINI Cooper Forum
post #1 of 5 (permalink) Old Jun 7th, 2014, 07:13 PM Thread Starter
Local Time: 07:36 PM
Quoted: 1 Post(s)
Lower front arm
Hi all, selling my o4 mini to a friend to buy a newer 1,, had MOT done 1 month ago and it has an advisory bush worn although MOT states no result in excessive movement
Bmw want 360 but i think this is just an advisory and may still pass ok next year??
Any thoughts welcomed please
paulcoz is offline
post #2 of 5 (permalink) Old Jun 7th, 2014, 08:09 PM
Local Time: 06:36 PM
Hi ya
Which bush ? It sounds like the front lower rear wish bone bush that your talking about.
If it's only an advisory it should be ok for now, but I would get it changed as it will effect your handling and tire wear.
It's hard to say really with out seeing it wether it needs to be changed or still has a little life left, was the mot done at mini, if it is the wish bone bush it's a 4 hour chargeable job and parts are about 60 ish a side.
marque is offline
post #3 of 5 (permalink) Old Jun 7th, 2014, 09:26 PM Thread Starter
Quoted: 1 Post(s)
Wish bone
Hi
Yes it is the rear wish bone bush there is a little play in it i can tell by putting my foot on the wheel and pushing, also when i pull away there sometimes is a judder for a second...Handling there is no problem but that is what the advisory was on rear bush
I wonder if that bush could actually be changed in situ? rather than dropping sub frame?
No it was not MOT @ bmw
paulcoz is offline
post #4 of 5 (permalink) Old Jun 7th, 2014, 09:42 PM
Hi ya
You can do it with out dropping the sub frame but TBH you don't have to drop it right out just slacken it off to drop it enough to be able to lower the rear end of the sub frame. Remove the bracket and bush them replace bracket and bush.
if I remember correctly the complete bush and bracket is about 8 more than the bush only
If you don't want to lower the frame your in to splitting the ball joints to remove the wish bone and there's a good chance you will damage the ball joint rubbers or the ball joint then you can get at the bush but you will need a special tool to remove and install the new bush.
If you drop the sub frame down to do it change you anti roll bar bushes the cheep and well worth changing while your there
If you can push on your wheel and it moves a lot get them changed
Hope this helps
marque is offline
post #5 of 5 (permalink) Old Jun 8th, 2014, 12:53 AM Thread Starter
Quoted: 1 Post(s)
cheers, with pushing with foot there is only a little play. If i grab the wheel to shake i would also say little play
paulcoz is offline
Front lower grille surround in black needed please 1980batty Second Generation MINI Exterior 2 May 26th, 2014 08:24 PM
control arm Joeytain Maintenance & MINI Care 2 Apr 15th, 2014 12:21 AM
Arm rest problem SBroad First Generation Interior & Ice 0 Jun 12th, 2013 11:28 PM
Lower control arm ball joints ttshinykit First Generation Faults & Fixes 0 Jan 13th, 2013 06:11 PM
Removing the black lower pieces to paint fenderless 33 Second Generation MINI Exterior 4 Dec 18th, 2012 10:55 PM
