Finally. Gen1 Power Steering Delete Kit Available Soon!!! - MINI Cooper Forum
post #1 of 4 (permalink) Old Jun 12th, 2014, 12:28 PM Thread Starter
Local Time: 12:55 PM
Condor Speed Shop is soon coming out w/ a UHMW Power Steering Delete kit for the Gen1 MINI & is gauging interest.
So please post if you want or need one.
Note:
Expected Steering resistance will be BETWEEN a GOOD PUMP & a DEAD PUMP in!
Why get one? A few good reasons below:
- Pump & Fan assembly is known to fail. New pumps are no different. Many have gone thru multiple pumps.
- Countless incidents of fire caused by the faulty pump. Check here & NAM.
- The PS system, its hoses & tank leaks easily. Eliminate them permanently.
-Kit is REVERSIBLE.
Should you decide to go back to stock, you can put back a working pump in.
-Relatively easy to install. Just remove the 2 hose banjo bolts on the rack, put the kit in place of the hoses.
-Shave some weight if you wanna extract the entire Powersteering system off the car.
-Get a more connected & direct steering feel. It will have greater turning resistance, YES, but NOT like having a DEAD Pump in. Ask e30/36, z3 & Miata guys who've done this.
- Affordable Temporary or Permanent Fix.
Condor is looking to offer the kit around or under $50 depending on interest. A group buy will be coming up very soon! So, please post on this thread if you want one. Don't wait for your pump to fail. You can just get 1 & store it for future use.
A new MINI-specific link will be put up soon by Condor Speed Shop to take orders.
Please note that I've no commercial involvement whatsoever w/ Condor. I'm just a concerned Gen1 owner who has been frustrated & saddened by seeing all these threads about this failure. My PS is working fine & I'm expecting a kit promised by Condor once testing is done.
This post is a humble way of THANKING Condor Speed Shop for helping the Gen1 MINI owners get an option for the PS woes.
This kit won't have been developed this easily nor this soon w/o the generosity of fellow member, c0op3r. He not only donated a working 06 rack but also shipped it to Condor for R&D. Gratitude should go to these 2!
Again, post if interested. Thanks!!!!
minsanity is offline
post #2 of 4 (permalink) Old Jun 13th, 2014, 06:30 AM Thread Starter
For all the reasons stated above, this kit has long been anticipated & similar threads on other MINI forums have drawn immense interest. But, not here? Well, there will be updates, just the same, once the kit is out, which is very soon.
post #3 of 4 (permalink) Old Jun 15th, 2014, 12:14 AM
SaltireCooperS's Avatar
Local Time: 10:55 PM
Australia
Interest registered! Currently looking to replace the reservoir and pipes which have reached EOL on my 2003 Gen 1, so if this kit is available soon, that'd be a good option....
Rozzer
2003 Indi Blue MCS (Saltire on roof)
Better a bad day on the track than a good day in the office
SaltireCooperS is offline
post #4 of 4 (permalink) Old Jun 5th, 2015, 06:00 AM
Local Time: 06:55 AM
Canada
Installed this on my 02 Mini a few weeks ago.
First, the steering is heavier than anticipated but not unreasonable. It is satisfactory for daily driving but prepared to use some arm muscles!
Parallel parking however is not easy...
Second, at least the steering effort is predictable and consistent vs the erratic assist from a failed PSP.
Unfortunately this is my autocross car and the steering with the delete is too heavy for the quick changes necessary so I will be removing this and installing a new PSP - dealer quoted just over $800 for just the part. Luckily I do my own work so I won't have to pay labour.
The Condor part fits well and only took about 45 minutes to install including the removal of the old PSP and reservoir. I left the lines and wiring in place and secured latex glove fingers over the ends/connectors to keep out dirt and moisture making reinstall of a new pump easy.
frankvan is offline
power steering gone heavy mini1987 First Generation MINI Cooper 3 May 22nd, 2014 06:08 AM
Power Steering Rack & Pinion Frustration VerticalMinded First Generation MINI Suspension 4 Jan 28th, 2014 09:14 PM
Need advise on power steering failure aioxen First Generation Faults & Fixes 11 May 28th, 2013 03:33 PM
Power Steering problems :( Shelley B First Generation MINI Cooper S 5 Feb 15th, 2013 01:13 PM
Power Steering pump on the blink...? cooper357 First Generation Faults & Fixes 8 Aug 21st, 2012 11:26 PM
