Passenger side not opening electronically - MINI Cooper Forum
post #1 of 9 (permalink) Old Jun 15th, 2014, 01:32 PM Thread Starter
Local Time: 07:25 PM
Hi from today onwards my passenger door on my 52 plate Mini One isnt locking or unlocking with the key or the button inside the car. The only way to unlock it is using the passenger side handle from inside the car. Does anyone know what this could be? Thanks in advance.
bowlingstefan is offline
post #2 of 9 (permalink) Old Jun 15th, 2014, 02:20 PM
Local Time: 06:25 PM
Hi ya
Sounds like the electrical actuator this link should have all the info you need a lot of this is rh but it will be close on the lh side
Central Locking Problems & Solutions - Mini Cooper Register Forum
Hope this helps
marque is offline
post #3 of 9 (permalink) Old Jun 15th, 2014, 02:48 PM Thread Starter
Thanks. Sounds complicated to me haha. I dont know much about cars. Do you know roughly how much a garage will change to fix it if i take it to them?
post #4 of 9 (permalink) Old Jun 15th, 2014, 03:04 PM
Hi ya
It's not a a hard job as long as you have the tools
If you take it to the garage it should only be about two hours max labour wise plus parts.
You could get a second hand one from a good breakers such as
http://www.minimatt.co.uk/bmw-mini-for-sale.html
http://www.bmspares.co.uk
http://www.minisparesuk.com
And I would also give the parts dept at your local mini a call sometimes there prices are good then get your guys to fit it
I would also get someone to have a look at the plug and wiring at the front of the door as well but it is normally the actuator
marque is offline
post #5 of 9 (permalink) Old Jun 15th, 2014, 03:22 PM Thread Starter
Okay thanks. It goes in for its MOT next week so il get the guy to look at it at the same time. Thanks for your help
post #6 of 9 (permalink) Old Jun 15th, 2014, 03:33 PM
No problem this link is what you basically need to do if they have never done it before
How to fix the locks and door handle on a Mini Cooper - YouTube
Hope this helps
marque is offline
post #7 of 9 (permalink) Old Jun 15th, 2014, 03:52 PM Thread Starter
Okay. Thanks again
post #8 of 9 (permalink) Old Jul 4th, 2014, 07:35 PM
05 s convertible
the passenger side door will lock electronically, but won't un-lock except with the inside door latch. I've only had the car a few weeks and this has been the case since I got it. I heard something slide forward inside the door (I think) upon hard braking the other day.
Could something have just come off in the door?
doxbike is offline
post #9 of 9 (permalink) Old Jul 5th, 2014, 08:45 AM
heathwebbo's Avatar
Not very likely, it will most likely be the actuator/door lock mechanism they are a common fault on minis. New ones can be found on ebay for around 65 dont be tempted to get a 2nd hand one as you will probably end up with the same problem
heathwebbo is offline
Tags: , , , ,
knocking noise from passenger left rear side dessieb123 MINI Cooper Diesel 1 Dec 18th, 2012 08:29 AM
HELP - Rattle/ Knocking Noise from rear passenger side wheel. thegreensnot Second Generation Faults & Fixes 8 Dec 10th, 2012 08:21 AM
Whistle/wind coming in via passenger side portishead100 First Generation Faults & Fixes 5 Nov 7th, 2012 02:36 PM
Passenger side Lever/switch under Glove Box? kerosenetrewthe General Discussion 2 Aug 9th, 2012 04:44 PM
front passenger side squeak ? while driving? tommytse22 Wheels, Tyres & Brakes 0 Aug 8th, 2012 09:53 AM
