aircon & heated rear window not working - MINI Cooper Forum
post #1 of 6 (permalink) Old Jun 23rd, 2014, 10:09 PM Thread Starter
Local Time: 09:45 AM
Is this coincidence or linked? neither of the indiator lights come on. I've checked the obvious fuses. Should the lights come on as soon as the button is pressed or are they fed from the releys?
neil1960 is offline
post #2 of 6 (permalink) Old Jun 24th, 2014, 06:52 AM
Quoted: 53 Post(s)
They are high power consumption items so would normally be fed through a relay/relays.
I dont have the wiring diagrams for a Gen 1 MINI so cant check for you unfortunately.
The Nun is offline
post #3 of 6 (permalink) Old Jun 24th, 2014, 07:42 AM Thread Starter
thanks - I know the aircon compressor & window element will be fed through relays - but what about the indicator light? Does anyone know if they are fed from the button showing power is being fed to the relay coil, or are they fed from the relay showing it is on?
neil1960 is offline
post #4 of 6 (permalink) Old Jun 24th, 2014, 01:57 PM
Local Time: 08:45 AM
Hi ya
have a look at the fuses in the engine bay fuse box the ones on the underside of the box, there a pain to get to. You will have to remove the airbox and ECM
Also it has been know for those fuse boxes to fail.
Hope this helps
marque is offline
post #5 of 6 (permalink) Old Jun 24th, 2014, 07:30 PM
Quoted: 1 Post(s)
Scotland
When checking the indecator lights do they come on when u out the hazard button?
If ur ac not working the mostly like cause will be your condenstor with the mini models but best but to have it checked out in a garage because you will need the ac equipment.
Aye you getting power up to your rear screen ?
Minitech93 is offline
post #6 of 6 (permalink) Old Jun 24th, 2014, 11:17 PM Thread Starter
sorry - I am meaning the indicator leds for the hrw & aircon. I assume there's no power to the hrw if this isn't coming on.
neil1960 is offline
convertible heated rear window not working Redcooperclubman First Generation MINI Convertible 2 Dec 26th, 2013 03:56 PM
2007 MCS R56 boot open warning light/message on dash, squeal & rear wiper not working LadyUK Second Generation Faults & Fixes 3 Oct 31st, 2013 06:27 PM
Rear jet not working properly Just Jay Second Generation Faults & Fixes 3 May 12th, 2013 10:05 PM
Aircon, Rear heated window and Sunroof stopped working williamtell First Generation Faults & Fixes 4 Nov 15th, 2012 10:10 PM
remote not working / also window problem miniXRY First Generation Faults & Fixes 2 Oct 7th, 2012 02:20 PM
