Park Distance Control (PDC) fault - MINI Cooper Forum
post #1 of 6 (permalink) Old Jun 25th, 2014, 01:35 PM Thread Starter
Local Time: 08:43 AM
Hello everyone,
I have Mini Cooper R50 2003m, and just noticed that Park Distance Control is not working. When driving reverse, nothing happens, not even single "BEEP" when driving close to the obstacle. I checked fuse and it is OK, i checked two, one from the left and one from the right sensors (to check two in the middle i need to take bumper out), they are OK, checked the wires - alive, got voltage from them.
I got to the nearest service and they checked my mini with computer, said no alarms from PDC so far.
Anyone had this problem before? Where should check? Thanks.
redh4t is offline
post #2 of 6 (permalink) Old Jun 25th, 2014, 01:48 PM
Local Time: 09:43 AM
Quoted: 53 Post(s)
There is a quick check you can do, if you turn on the ignition, without engine running, and then select reverse gear. if you go around and listen to each sensor on the bumper if its working you will hear it clicking, no click means a duff sensor, if all dont click then it means theres something wrong with the supply to them, maybe the control unit itself?
The Nun is offline
post #3 of 6 (permalink) Old Jun 25th, 2014, 01:53 PM Thread Starter
Shouldn't then PC diagnostic show that control unit is broken?
redh4t is offline
post #4 of 6 (permalink) Old Jun 26th, 2014, 07:30 AM
Quoted: 53 Post(s)
Ive looked through my manual and there doesnt seem to be a diagnostic code for the rear sensor system not working.
Maybe thats why the garage says nothings showing? was it MINI?
The Nun is offline
post #5 of 6 (permalink) Old Jun 26th, 2014, 11:39 AM Thread Starter
I checked and they are all clicking. The weard thing is that yesterday when i was checking them they worked fine. Today they don't again. I was walking around them and they are clicking but no beeping sound in salon. Any ideas?
redh4t is offline
post #6 of 6 (permalink) Old Jan 18th, 2015, 03:22 PM
Quoted: 1 Post(s)
My park sensors have never worked since I purchased it a month ago. When I put it in reverse, the is no beeps heard. I have checked the PDC/PAS Fan Fuse and that is intact. There is no clicking from the sensors. I plugged in INPA and got the following:
24 voltage ultrasonic sensor general
Error frequency : 50
Short circuit to ground
Error present
Can someone point me in the right direction please. Thanks
Gizmotech is offline
MCS Clubman rear parking distance control juge Second Generation Faults & Fixes 1 Dec 14th, 2013 03:12 PM
HELP PDC control module location andrewiow88 First Generation Faults & Fixes 3 Sep 13th, 2012 03:49 PM
