Steering Pump Or Not Steering Pump problem.. - MINI Cooper Forum
post #1 of 2 (permalink) Old Jul 1st, 2014, 08:04 PM Thread Starter
sharkie's Avatar
Local Time: 07:17 PM
Ireland View sharkie's Chili Red & White 1st Gen MINI Cooper S Profile
Hi,
HELP... Before i go a pay stupit money on a steering pump on the advice of a Main dealer..
Steering is Quite Heavy (Not like there is no Assistance from the power steering pump which you can hear as you turn the wheel ) but heaver then it should be, Main Dealer insistes its the Steering pump but if you try to turn the wheel without the engine on it even Heavier but with the engine on it its a lot lighter to turn but heavier then it should , it also wont return to centre when you go around a corner it's progressivly harder to turn at say 1/2 turn ether left or right,
so
1. steering is very heavy (but you can hear the pump working as you turn the wheel and when you go full lock )
2. pump much be doing somthing as it not as hard to turn as it is with the engine off.
3. steering wheel wont return to straight ahead when you complete a turn.
4. stearing feels harder to turn at different spots as you turn the wheel.
any thing i can check or is there a way to check if the pump is 100% ok....
sharkie is offline
post #2 of 2 (permalink) Old Jul 2nd, 2014, 12:38 PM
Local Time: 04:17 AM
Quoted: 166 Post(s)
Australia Male
Garage
I have just recently been down this path and in the end, the pump is shot and you need to replace it. If your doing it yourself for the 1st time, work on around 3-4 hours to do the complete job and make sure you use the correct power steering fluid when you refill it.
My pump was heavy steering and when it was running was OK but after 5 mins in traffic, the pump would cut out and I would have no power steering. After 5 mins to allow it to cool, the pump would work. My tell tale was either sudden heavy steering or I couldn't hear the pump running and knew what to expect.
If your doing it yourself, jack the car up as high as the jack stands allow to gain access to the two rear bolts you will need to remove and replace the low pressure hose clamps with screw tightened clamps, the OEM clamps are rubbish. Also replace the O-ring to the high pressure pipe.
In regards to the steering getting harder after 1/2 a turn, mine was the same with the faulty pump stopped as there was no way for the fluid to be transferred so there will be a pressure build up with the fluid being unable to circulate.
Milpol is offline
power steering pump & fan replacement Qs canucklehead First Generation MINI Cooper S 2 Jun 7th, 2014 12:59 AM
Weird starting problem / FUEL PUMP, FILTER ? Schakal General Discussion 0 Oct 31st, 2013 10:55 AM
R50 power steering pump Rally370 First Generation Faults & Fixes 2 Jul 24th, 2013 02:23 PM
Another power steering problem! starky5 First Generation Faults & Fixes 1 Oct 1st, 2012 10:03 PM
Power Steering pump on the blink...? cooper357 First Generation Faults & Fixes 8 Aug 21st, 2012 10:26 PM
