Passenger door won't open - MINI Cooper Forum
post #1 of 15 (permalink) Old Jul 8th, 2014, 08:14 PM Thread Starter
Local Time: 03:21 PM
Hi all,
So I have had an issue with my passenger side door where i can only open it from the inside. Recently went to take a look at the door, took the inside of the door off and had a look around.
I couldn't see anything out of the ordinary however I seem to have managed to mess up the inside door too, both mechanisms are not unlocking the door now.
I notice the interior door handle cable is kind of naff. Looking to have to replace this cable too.
My main concern is that I cant take the lock out of the door as i'm unable to open it. Anyone able to help?
hayd is offline
post #2 of 15 (permalink) Old Jul 8th, 2014, 10:12 PM Thread Starter
Bump
hayd is offline
post #3 of 15 (permalink) Old Jul 8th, 2014, 11:47 PM
Local Time: 02:21 PM
Hi ya
Remove the door trim and try to lock/unlock you my find the trim is stopping it, if it still does not work key or handle I would look at your door actuator they do seize up. You can remove it and clean them up and give them some lub.
Hope this helps
marque is offline
post #4 of 15 (permalink) Old Jul 10th, 2014, 12:53 PM Thread Starter
Hi when you mean door trim do you refer to this as being it?
As i mentioned I have taken the inner door frame off prior to shutting the door. also just to mention its passenger side.
hayd is offline
post #5 of 15 (permalink) Old Jul 10th, 2014, 01:45 PM Thread Starter
I have attached some images, If you see the gold looking latch If i move that down the door does not open however if i do the same on a working door it works. I have a feeling there's something wrong with the lock but how can i get this out?
ID:	176473   Click image for larger version
ID:	176481   Click image for larger version
hayd is offline
post #6 of 15 (permalink) Old Jul 10th, 2014, 04:03 PM Thread Starter
Is there no way i can get the door open to remove the lock actuator?
hayd is offline
post #7 of 15 (permalink) Old Jul 10th, 2014, 05:44 PM Thread Starter
270 views and no suggestions?
hayd is offline
post #8 of 15 (permalink) Old Jul 11th, 2014, 12:29 AM
Hi ya
I think if you push down on the gold arm in picture 1 the door should open I think this is the latch release. It's been a while since I was in there on mine.
I would drop the window about 1/2" while you are messing with the latch Incase the window does not drop when you try to open the door it could break the glass.
Hope this helps
marque is offline
post #9 of 15 (permalink) Old Jul 11th, 2014, 12:46 AM Thread Starter
Hi I've tried pushing down on the latch release but nothing happens
hayd is offline
post #10 of 15 (permalink) Old Jul 12th, 2014, 01:01 PM Thread Starter
Anyone got suggestions?
hayd is offline
post #11 of 15 (permalink) Old Jul 12th, 2014, 08:22 PM
Quoted: 2 Post(s)
Just to say - sorry, i can't really help as I'm not a techie type Mini owner - but i do sympathise.
My passenger door can only be opened from the outside (although you have to squeeze it reallllly hard!); although from the inside only my daughter can open it by carrying out a waggling pattern on the door latch, but my son cannot open it at all from the inside.
I've had it repaired three times and three times it's stopped working again. Shortly will be going for forth time lucky so I wish you well with your own endeavours!!
halesowenmum is offline
post #12 of 15 (permalink) Old Jul 13th, 2014, 12:27 PM Thread Starter
Hi, thanks for the reply.
Just an update: I was able to pull on the interior door cable and was able to open the car. However the door only lock when pushed into the car, it appears when i try lock it with the key it has no affect?
Also the exterior door handle mechanism doesn't unlock the door. Does this suggest I buy a new actuator?
I should be able to take the lock actuator out but I dont know what im looking for after.
hayd is offline
post #13 of 15 (permalink) Old Jul 13th, 2014, 04:34 PM Thread Starter
Just an update:; today I took the actuator out and had a look, found lots of
"yellow lumpy stuff" possibly just grease?
I played around with having the actuator plugged into the electric socket and seeing if I could see any real issues.
In my images your find at the bottom of the actuator by the pale looking straight part which controls the electrical unlock/locking from the key, one is straight against the side and one is angled.
Now I found that it would only unlock/lock if straight and sometimes it wouldnt.
If it was angled it would do neither.
But if I had it straight i was not able to unlock the door using either inside or outside mechanism.
Is this a case of buying a new actuator?
ID:	176625   Click image for larger version
hayd is offline
post #14 of 15 (permalink) Old Jul 14th, 2014, 11:24 AM Thread Starter
Anyone got any thoughts/input on this?
hayd is offline
post #15 of 15 (permalink) Old Jul 14th, 2014, 03:43 PM
heathwebbo's Avatar
There is obviously a problem with the actuator so I would replace it with a new one. You can get them off ebay for around 65 but dont be tempted to get a 2nd hand one or you may end up with the same problem
heathwebbo is offline
Tags: , ,
It will not open the trunk (boot) please help me!!! elamelam First Generation MINI Cooper S 0 Dec 27th, 2013 06:06 PM
Unable to operate Driver's window if passenger door open TheGadgetMan Second Generation Interior & Ice 1 Jun 5th, 2013 09:45 AM
Passenger door doesn't open from inside... Richardestys Second Generation Faults & Fixes 0 Apr 1st, 2013 09:20 PM
Passenger door won't open. AT ALL, help. Sinned180 First Generation MINI One 0 Mar 12th, 2013 12:55 AM
Passenger Door Won't Open wildmind_uk First Generation Faults & Fixes 1 Jan 24th, 2013 04:42 PM
