Possible Lambda Sensor Fault??? - MINI Cooper Forum
post #1 of 1 (permalink) Old Jul 11th, 2014, 12:49 PM Thread Starter
Local Time: 01:39 PM
I'm having an intermittent problem with my 2003 Mini One (r53) and was wondering if anyone could provide input?
When I start the car first thing in the morning it runs absolutely fine for a couple of minutes, pretty much long enough for me to get halfway down the road. The car then starts losing power and the revs fluctuate up and down.
Turning off the engine and starting up again seems to solve the problem for another 2 minutes. Once the car has done this once or twice and is starting to warm up the problem stops.
It doesn't always do this but I've noticed it tends to happen when it's damp weather and if there's heavy rain it can do it in the middle of the day (possibly due to water spraying up under the car?).
My only clue is that once, during a torrential downpour, it had the same problem and the check engine light came on. The AA read the code and it came out as "P0132 O2 circuit High Voltage - Bank 1 sensor". The error code hasn't reappeared since but I still have the same problem.
I asked my local garage to check the lambda sensor out during it's service and they said the sensor appeared fine and was giving normal voltage readings. But as I mentioned this is an intermittent fault usually first thing in the morning (although it's almost becoming a daily problem!).
Should I go ahead and change the sensor? or are there other potential sources for the problem I should get the garage to checkout first?
Any advice would be greatly appreciated. Many thanks in advance.
MADscientist is offline
04 Mini Cooper failed MOT on Emissions. Lambda??? Frosticles First Generation Faults & Fixes 0 Oct 12th, 2012 06:51 PM
Lambda sensor cooper s extremepie Second Generation Faults & Fixes 6 Sep 14th, 2012 09:39 PM
