drivers window not opening when open door - MINI Cooper Forum
post #1 of 7 (permalink) Old Jul 13th, 2014, 04:34 PM Thread Starter
Local Time: 02:29 AM
hi all i have a mini cooper 2006 i have just bought roof bars and
it relies on the window opening abit when you open the door the passenger side
is fine but drivers not working all windows and central locking works fine just
this hope someone can help
Boothy01 is offline
post #2 of 7 (permalink) Old Jul 13th, 2014, 04:38 PM
heathwebbo's Avatar
Local Time: 01:29 AM
It might just need resetting, try putting the window down let go of the switch then press & hold the button in the down position for around 10 to 15 seconds. Put the window up let go of switch then press & hold in the up position for 10 to 15 seconds
heathwebbo is offline
post #3 of 7 (permalink) Old Jul 13th, 2014, 04:40 PM
heathwebbo's Avatar
First check your interior light is coming on when you open the door, if it isn't your problem is most likely the door switch that controls the interior light & window drop
post #4 of 7 (permalink) Old Jul 13th, 2014, 05:00 PM Thread Starter
hi just checked and light is not coming on what part will i need and is it hard to fit
thanks
Boothy01 is offline
post #5 of 7 (permalink) Old Jul 13th, 2014, 05:47 PM
heathwebbo's Avatar
It will most likely be the door lock actuator, they are known for problems on the gen ones. They are around £65 off ebay & fiddly but not too hard to fit. Don't get a 2nd hand one or you may end up with the other problems they give. I will go out & check mine to double check that the lock/actuator is the part that works the window
post #6 of 7 (permalink) Old Jul 13th, 2014, 05:54 PM
heathwebbo's Avatar
Yes I can confirm the door lock/actuator works the window drop I just opened my door & the window dropped as normal I then closed the door latch with a screwdriver (door still open) & the window went back up
post #7 of 7 (permalink) Old Jul 13th, 2014, 06:00 PM Thread Starter
thanks i will look for one
Boothy01 is offline
Driver's side door hard to open sometimes lipwak Second Generation MINI Cooper 4 Mar 28th, 2016 12:50 PM
Driver's door window fault Ludwig MINI Countryman 15 May 23rd, 2014 07:34 PM
help: Passenger window doesn't slide back up when closing door Niral General Discussion 1 Jan 14th, 2014 10:06 PM
Unable to operate Driver's window if passenger door open TheGadgetMan Second Generation Interior & Ice 1 Jun 5th, 2013 08:45 AM
Passenger door doesn't open from inside... Richardestys Second Generation Faults & Fixes 0 Apr 1st, 2013 08:20 PM
