Noisy fan. Temp sensor? - MINI Cooper Forum
post #1 of 2 (permalink) Old Jul 16th, 2014, 07:59 PM Thread Starter
Local Time: 01:53 PM
I've had the noisy fan problem that worsened last week resulting in a rapid loss of water and a boiling industrial kettle like sound.
We discovered a leak on the radiator that has since been fixed - This hasn't stopped the noise, the the leak has lessened - (still losing water but we think this is air in the system).
We just replaced the thermostat and now the water isn't boiling and bubbling as it was previously, but the fan still comes on straight away from a cold start with the temp gauge showing half way - The fans stayed on when turning the car off up until we changed the thermostat.
The car is definitely not overheating now, but the fans still persist. Does this sound like a definite faulty coolant sensor or is there something else it could be?
Thanks in advance.
Green-chameleon is offline
post #2 of 2 (permalink) Old Jul 25th, 2014, 01:40 PM Thread Starter
Any ideas as to what the range is on the temperature sensor? Our heated range is 1.95 and cold is 8.44
2002 Cooper S R53 Fan relay resistor dorman 902-706? Toymaker23 First Generation Faults & Fixes 2 Dec 18th, 2014 12:18 PM
Fan and Temp Gauge Problem nikkiii93 Second Generation Faults & Fixes 1 Apr 11th, 2014 07:36 AM
Fault codes p0172 & 0117 coolant temp sensor landyman Welcome New Members 1 Feb 26th, 2014 08:03 AM
