Separated harmonic balancer - MINI Cooper Forum
post #1 of 2 (permalink) Old Jul 27th, 2014, 03:17 AM Thread Starter
Local Time: 03:57 PM
Recently I heard a relatively high frequency pulley noise from my 2003 base. shortly after the serpentine belt shredded. After removing the belt and tensioner. I found the tensioner pulley to spin dry. After replacing the tensioner pulley and belt , the noise went away. After driving a couple of miles, there was bang followed by a loud grinding. After removing the serpentine belt a second time, I found the outer ring of the harmonic balancer had separated from the inner hub. Is this common?
Trelawny is offline
post #2 of 2 (permalink) Old Jul 27th, 2014, 08:03 AM
heathwebbo's Avatar
Its a common problem on the early S models, I changed mine to a solid pulley
heathwebbo is offline
Tags: ,
Fitted new Harmonic Balancer, belt jumping off? BubbaDooDoo First Generation MINI Tuning 5 Apr 21st, 2013 07:12 PM
