Freon Leak after clutch repair - MINI Cooper Forum
post #1 of 1 (permalink) Old Aug 4th, 2014, 03:11 PM Thread Starter
Local Time: 11:18 PM
Just replaced the AC clutch coil on my 2003 mini cooper. Did it by dropping the compressor out the bottom and not opening the system. Now it seem I have a huge Freon leak from around it. I have 0 psi pressure and when I try to put Freon in I can hear the leak and feel the gas coming out from under the clutch.
2 things:
After removing the spring rings I still had the tap the clutch pulley with a small hammer to get it off. The taps were numerous but very light. The pulley came right off.
Also I think I got the inner ring in correctly but who knows.
Can someone tell me what the possible causes of the leak is. Would the ring clips not seated cause this. Did I screw it up bad by tapping the clutch (seems as though the seals would have to be very fragile for that to happen).
Can someone give me some insight and help here? This is very frustrating after all that work.
st_man is offline
Tags: , ,
Clutch 2005 Mini Cooper S capacitytube First Generation Faults & Fixes 2 May 16th, 2014 04:50 PM
Looking for feedback on clutch issues ('08 Clubman S) Blue08ClubmanS MINI Clubman 8 Jan 25th, 2014 09:39 AM
Time lapse repair - Clutch replacement MINI Cooper S 2006 mab01uk First Generation Faults & Fixes 0 May 14th, 2013 12:13 AM
Stubborn Dealership over Clutch Bleed MiniDeLux Second Generation Faults & Fixes 0 Mar 18th, 2013 11:45 AM
What RPM do you start 1st with? thewhitenight000 First Generation MINI Cooper 2 Aug 8th, 2012 07:19 AM
