Squeaky doors/buzzing speaker grills Well, after two trips to the dealership, my buzzing speaker grill problem was fixed, but the buzzing door card issue persisted. So, frustrated with the service I was getting at the dealership, I took matters into my own hands. I'm happy to report that everything is fixed, and I'm going to tell everyone who's not afraid to take their doors apart how to fix it.
Just so everyone knows, the speaker grills are replacable. The dealership drilled the pins out of the original grill, then removed it. The new grill is held on by push-on clips instead of the melted pins which means that if they start rattling, the clips can be pushed down further onto the pins to tighten them up. What this means (at least for me), is that when I replace the speakers with a set of aftermarket speakers, I should be able to remove the original grills and use the ones that come with the new speakers and mount the speakers directly to the door card instead of making adapters to mount the speakers directly to the door.
Anyway, on to the door card! The dealership fix was to try to put thin rubber washers on the push-pins that hold the door card on, and tighten the crap out of the screws which not only made matters worse, but resulted in a stripped screw hole as well. When I took the door panels off, it immediately became apparent what the problems were -- the rubber seal that meets the elliptical portion of the door card and the plastic pins. The fix is simple enough -- silicone grease (aka, dielectric grease). I applied a thin coat to both the gasket itself and to the back of the door panel where it meets the seal. I also smeared some around each of the holes where the pins push in, and some on the pins themselves. When I put the door cards back on, I only snugged down the screws, I didn't see the need to over do them.
I must warn against using anything other than silicone grease (i.e., petroleum jelly, grease, etc). It will attack the rubber seal and possibly the plastic because of the petroleum base. Silicone grease is safe for the surfaces. The standard dielectric grease may be a bit too thin though, so a thicker silicone grease is desired. I found a aerosol can of the stuff at Pep Boys, and it's *very* thick. The brand name is CRC, and the can reads "Technician Grade Dielectric Grease Compound and it's a 3.3oz can. I found it in the engine cleaning/oil additive section. The bar-code is 78254 05105, although I don't know if that's going to help anyone or not.
Unfortunately, I didn't take any pictures. But it should be self-evident where to apply the silicone when you get the door apart. I drove it around today, and both doors are completely squeak free! I can finally enjoy driving the car again! |
