Water Leaking On To The Floor - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Feb 27th, 2003, 10:58 AM
minitech's Avatar
Let's Motor...
Send a message via MSN to minitech
Local Time: 08:12 AM
United States View minitech's Classified Ads
DIY Water Leaking On To The Floor
has any body had there car develop water on the front floor (passenger-driver side).if you do or have had it fixed please mail me or just reply to this.it might be you sunroof drains not hooked up properly and leaking to the car.
let's motor
Old Feb 27th, 2003, 11:02 AM
Paul's Avatar
MINI2 No.1
Local Time: 01:12 PM
England Male
Some people appear to have had this problem, try a search for either/or both: water, leak* in faults and fixes, I'm sure there's been discussion on this before.
Paul
Old Feb 27th, 2003, 12:20 PM
TheBlackKnight's Avatar
Local Time: 02:12 PM
United Kingdom View TheBlackKnight's Solid Black & White 1st Gen MINI Cooper Profile
There was a water ingress problem on early build MINIs, which resulted in leakage into the BC1 unit! This is, I believe, not present on the later models - you might want to keep an eye out for any electrical faults as well?
boot is leaking water MrLee2006 First Generation Faults & Fixes 3 May 14th, 2007 04:48 PM
installing rubber floor Mini floor mats gfoye Maintenance & MINI Care 3 May 1st, 2007 07:36 AM
water swooshing noise = leaking head gasket! robfish1985 First Generation Faults & Fixes 1 Feb 15th, 2007 03:36 PM
Water leaking into Mini when it rains!!! artlies First Generation Faults & Fixes 5 Nov 1st, 2004 07:02 PM
Rain = over 1" water on driver side floor jcam711 First Generation Faults & Fixes 0 May 15th, 2004 01:26 AM
