Cooper Auto - Kangerooing at low speed My Cooper (auto Chili-pak) kangaroo jumps from 0-10mph. I've had loads of software updates and wire loom replacements but it still kangaroo jumps. Mini service don't have a clue (obviously!). Any help out there? |
| Yep, I get that too. Sometimes it seems worse than others, but it could just be due to differences in driving conditions at the time. Hopefully now that 32.1 seems to have solved all of the more major problems, further software upgraes will smooth out these remaining little niggles. Since there are no pre-set gears in a CVT, there should be no "dividing lines" between gears. It is much better in Sport mode (even more evidence that it is something that they should be able to work out)so if it is really bothering you, just do as olalla said (and I sometimes do it too) and switch over into Sport mode if you're in a situation where you're traveling at these low speeds a lot. PigLick |
| Low speed rattle from front right?? | rntheald | First Generation Faults & Fixes | 15 | Jun 13th, 2006 03:49 PM |
| Seat Airbag deployed at low speed!!!???? HELP | chew | First Generation Faults & Fixes | 3 | Sep 1st, 2005 01:39 PM |
| At 43k, MINI Cooper S develops a mooooo at low speed acceleration - et al | GMINI | First Generation Faults & Fixes | 8 | Jul 28th, 2004 12:48 AM |
| shaking at low speed | sketcher | First Generation Faults & Fixes | 2 | Oct 1st, 2003 05:54 PM |
| Lights dim when steering at low speed! | Varse | General Discussion | 9 | Dec 20th, 2001 11:33 AM |
