Bonnet help... - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Apr 15th, 2003, 04:10 AM
MiniMan7's Avatar
Let's Motor.
Send a message via MSN to MiniMan7
Local Time: 10:13 AM
Canada View MiniMan7's Electric Blue & White 1st Gen MINI Cooper S Profile
Bonnet help...
I notice my bonnet to be alittle off. When its fully closed, the right side comes down more than the left side. I'd say there is about a quarter of an inch difference. Also, the right wheel arch is unaligned. I think my whole bonnet my be alittle off of what its supposed to be, heres a few pics, hopefully you guys can help. Thanks!
Overall view, notice the right side of the bonnet is lower than the left side:
[Click to enlarge]
Right side of the bonnet:
[Click to enlarge]
Left side of the bonnet:
[Click to enlarge]
Right wheel arch (I placed a white paper towel in order to see the displacement better):
[Click to enlarge]
Left wheel arch (I placed a white paper towel in order to see the displacement better):
[Click to enlarge]
The last two pics show how the bonnet comes too far down and is not lined up with the arches correctly.
Note: When I refer to the right and left side of the car, I'm referring the side it would be when sitting in the car, not when looking at it.
Old Apr 15th, 2003, 04:39 AM
tip's Avatar
tip
Motor On!
Local Time: 08:13 AM
Canada View tip's British Racing Green & White 1st Gen MINI Cooper Profile
Miniman,
Take the car to Budds, I believe that they can adjust the bonnet throught the side vents. It is probably jus a minor thing.
Charles
BRG/W MCS bonnet stripes ,white wheels, sport package, sunroof, heated seats, Alta pulley, Alta intake
Old Apr 15th, 2003, 04:43 AM
MiniMan7's Avatar
Let's Motor.
Originally posted by tip
Miniman,
Charles
Sounds like a good idea, I'm going to bring it to my dealership (Mini Woodbrigde) when I have my exhaust installed and have them take a look, I'm just scared that I might get a big fat bill since my Mini was in an accident and the whole bonnet was replaced, needless to say, I will still ask them to fix it. Thanks Charles.
Old Apr 15th, 2003, 08:02 PM
Local Time: 09:13 AM
United States View sjbartnik's Electric Blue & White 1st Gen MINI Cooper S Profile
I wonder if the bonnet/rear hatch are fitted by robot or by hand. My rear hatch was fitted a little off, resulting in it standing proud of the body at the lower right corner, causing a small water leak.
A T-40 driver and about 20 minutes adjusting the right side hinge fixed the problem but I thought that was a little unusual. Perhaps beer is served during lunch at the factory?
Sean Bartnik
2003 MINI Cooper S
Old Apr 15th, 2003, 08:04 PM
OHHHH. Well yeah then it's probably related to the accident and subsequent repair. If the bonnet was replaced I imagine they didn't do as good a job as the factory in fitting it.
So even if they won't fix it under warranty, you should be able to get it fixed through your car insurance since it's related to your accident repair.
Sean Bartnik
2003 MINI Cooper S
Old Apr 15th, 2003, 08:06 PM
Speedd's Avatar
Don Vito
Local Time: 01:13 PM
United Kingdom View Speedd's British Racing Green & White 1st Gen MINI Cooper Profile
Hey CoopRaNite has the same problem and is due to be taken in this weekend. I was told of the slight alignment at the last meet we had here by Rich
Keep us posted M7
Anand
Does my @rse look big in this broom broom www.totalMINI.com will be right back
Old Apr 16th, 2003, 12:00 AM
Minty's Avatar
Man in the know!
Send a message via MSN to Minty
mine had the same problem...after a slight bump get it back to the dealers, they can adjust it. mine is fine now!
MINI-3 @ Cotswold MINI | BMW-four @ Cotswold BMW | E-Mail Me | Minty - Part of the IT Crowd!
Old Apr 16th, 2003, 01:22 AM
MiniMan7
Hi MiniMan7
The bonnet is easily adjusted on the front bonnet catches, i have also had the same fault which wasnt the bonnet out of adjustment but the plastic wheel arch mouldings which had some broken retaining clips on it due to careless technicians pulling up on the trims/bonnet so they can put the ramp legs under the car to lift it.
This is only an idea??
Old Apr 16th, 2003, 01:24 AM
Please note that the main cause for the wheel arch trims to be loose is from careless technicians lifting up on the front wings/bonnet and not the bonnet out of alignment.(this is in most cases im not saying its gospel!)
I am speaking from experiance here from when the car was first launched.
Local Time: 05:13 AM
United States View retroom's Liquid Yellow & White 1st Gen MINI Cooper Profile
The body shop didn't fix it right, you or your insurance shouldn't have to pay more to get the hood aligned correctly. Take it back to the body shop and have them fix it.
retroom
2003 MC,LY/W, sport package, wht wheels, cruise, chrome, Kaleido cloth/black, OB computer
Old Apr 16th, 2003, 04:42 AM
MiniMan7's Avatar
Let's Motor.
I was thinking about getting the body shop that repaired it to fix it since its a life time warranty with them. However, for the sake of getting it right the first time I'm going to go with my Mini dealership since they're much more experienced with Mini's. I don't think its the plastic trims that are out of wack, but when I bring it near the end of the month I'll let you guys know what happens, thanks for the help!
Old Apr 16th, 2003, 12:25 PM
That seems sensible. Who recommended the body shop to begin with?
retroom
Old Apr 16th, 2003, 09:35 PM
MiniMan7's Avatar
Let's Motor.
retroom
Our insurance company had a list of all body shops they recommended, since we heard good things about this place, we went there. They did a very nice job, except for replacing the bonnet.
Getting a dent out of the Bonnet Jammy Dodger Maintenance & MINI Care 6 Feb 19th, 2006 12:39 PM
Outlines on bonnet stripes - Black bonnet stripes on PW/B Pamster First Generation MINI Exterior 37 Feb 13th, 2006 12:41 PM
Why??? Bonnet Damage camminich First Generation MINI Cooper S 19 Sep 22nd, 2004 05:51 PM
Aligning your bonnet? MiniMan7 First Generation Faults & Fixes 19 Sep 4th, 2004 11:38 PM
New bonnet Rouskous First Generation Faults & Fixes 4 Jan 28th, 2003 10:20 AM
