Dsc/tire Pressure Light Poll - MINI Cooper Forum - MINI2 Mini Cooper Forums
View Poll Results: Has your DSC/TIRE PRESSURE light come on for no apparent reason?
Yes. but I never took it in for service 13 44.83%
Yes I took it in for service and it has been repaired 2 6.90%
Yes, I took it in for sevice but they did not repair it 3 10.34%
No it has not happened to me 11 37.93%
Voters: 29. You may not vote on this poll
Old Apr 25th, 2003, 09:53 PM
Local Time: 01:14 PM
Have you successfully had this problem repaired by MINI?
Cooper S Brg/w sport package
Old Apr 25th, 2003, 10:33 PM
MICKEY's Avatar
Local Time: 02:14 PM
United Kingdom View MICKEY's Chili Red & Black 1st Gen MINI Cooper S Profile
Arn't they 2 different lights ????
I've had the dcs light come on, but I know why that happened
And I've had the tyre alert light come on (had a puncture) but I voted no as they've not come on for no apparent reason (please let it stay that way )
Mick
Old Apr 25th, 2003, 10:41 PM
Martin L's Avatar
MINI defector
England Male View Martin L's Astro Black & Body Color 2nd Gen MINI Cooper Profile
It happened to me the other week, so I searched in MINI2 and low and behold found the fix. If it does happen again, I will however get my dealer to look at it.
MICKEY the DSC light and tire presure light come on both together for no apparent reason. DSC/ASC+T does stop working too
MINI, RX8 and MX5 - Done those............. It's now TTime
Unofficial MINI2.com bean counter
Old Apr 25th, 2003, 10:58 PM
Charger_Pete's Avatar
Mini 2 Slap Head
Send a message via ICQ to Charger_Pete Send a message via AIM to Charger_Pete Send a message via MSN to Charger_Pete
United Kingdom View Charger_Pete's Electric Blue & White 1st Gen MINI Cooper S Profile
This happened to me and the DSC light stayed on. Couldn't sus out why. I had a look in the owners manual and it said that the tyre pressure light comes on after 'enthusiastic' driving
The next morning i drive off to work as normal (albeit with the start..drive...stutter problem ) and the light cleared itself and all was back to normal. Just one of those things i guess. Thinking about it though....if front tyres get a thrashing then tyre pressures will rise. Fronts will get hotter than rears and thus cause in-balance. Maybe this will fool the system into thinking it has a flat somewhere?? Suggestions anyone else???
Old Apr 26th, 2003, 01:42 AM
The fix you are talking about is the reset button beneath the parking brake.
I dont really regard this as a fix. It's more of a work around solution.
I's like when Window's locks up on your PC. Yes, you can fix it by rebooting the system. But the lock up will eventually happen again, until the root cause is corrected.
Im looking for the root cause. And trying to prove this is a common problem which rates BMW attenion.
Old Apr 26th, 2003, 09:18 PM
Red Cooper's Avatar
Master of Disaster
Local Time: 06:14 AM
United States Male
This appears to be a Cooper S problem - please correct me if I am wrong.
I have DSC on my Cooper and haven't had this problem - touch wood...
RC
Old Apr 27th, 2003, 12:10 AM
grumpy07470's Avatar
Send a message via Yahoo to grumpy07470
Local Time: 08:14 AM
United States View grumpy07470's Indi Blue & White 1st Gen MINI Cooper S Profile
Blue Cooper
It has happened to me twice. Just shut it down and re started,continued to drive and the lights went out in about 100' or so.
DSC / Tire Pressure Alert Showing Malfunction ? kshapiro First Generation Faults & Fixes 144 Sep 5th, 2009 09:21 PM
DSC/Tire Pressure Light On -DSC Kicking in at odd times noord First Generation Faults & Fixes 2 Jun 25th, 2003 11:59 PM
Has anyone had the dsc tire pressure light fault sucessfully repaired? KAMAKAZI First Generation Faults & Fixes 0 Mar 29th, 2003 10:37 AM
DSC/Tire pressure light Grinder First Generation Faults & Fixes 1 Oct 25th, 2002 12:54 PM
DSC + Tire warning light nosaj First Generation Faults & Fixes 1 Aug 9th, 2002 02:13 AM
