acoustic ignition key warning on/off - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old May 1st, 2003, 03:49 AM
Local Time: 09:14 AM
The users manual says that the warning chime, if the key is left in the ignition when the door is open, can be turned on/off. The tech that looked at my car printed out all the "memory" setting that can be configured and this was NOT one of them. He didn't know of any other way to turn chimes off. Maybe it is done in a different manner than all the other "memory" settings. Anybody ever had this turned off? In BMW's you leave the key in, open the door (chime starts) but then pull the key out and stick it back in and the chime stops, but in MINIs the chime will start again. The reason i want to do this is because I want to be able to have the ignition switched to the accessory position but have the door open with no chime.
Old May 1st, 2003, 08:02 AM
BruceK's Avatar
Moderator & Sponsor
Local Time: 07:14 AM
I believe the warning chimes for key in the ignition are a federal regulation in the US , not just a courtesy feature. It's much like the seat belt warning light and buzzer when you start the car without putting the seatbelt on.
As such, perhaps the key warning chime can be disabled in other markets, but probably not in the US market.
(You mentioned the accessory position - you do know the radio works without the key, right?)
Old May 7th, 2003, 03:42 AM
yes radio, but power outlet (cig lighter)...
does not work with out the key turned on.
Old May 7th, 2003, 07:43 AM
MiniMan7's Avatar
Let's Motor.
Send a message via MSN to MiniMan7
Local Time: 10:14 AM
Canada View MiniMan7's Electric Blue & White 1st Gen MINI Cooper S Profile
Lets put it this way...
The owners manual says alot of stuff... and some stuff is not entirely true.
Old May 7th, 2003, 07:50 AM
nfo
i had this problem today, i had the cigarette lighter being used by cellphone charger when i was cleaning the car and without the key, only the radio will work! lame! i wish that chime would at least stop after a min. or so!
Price of a replacement ignition key _john_ General Discussion 6 Jan 2nd, 2012 08:49 AM
Key not turning in ignition MarkW19 First Generation Faults & Fixes 23 Feb 7th, 2007 03:29 PM
Acoustic low fuel warning flipper First Generation Interior & Ice 9 May 20th, 2003 06:37 AM
Ignition key in position 2? jonesl General Discussion 11 Jan 25th, 2003 06:28 AM
ignition key jammed! IDONEY First Generation Faults & Fixes 3 Aug 20th, 2002 11:26 AM
