Off throttle, 2k rpm lurch - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old May 7th, 2003, 04:26 AM
L8 Apex
Guest
Posts: n/a
Jan 03 build. Anyone else got this? It happens in any gear, when off the throttle (completely) and the tach dips below 2k rpm, and then the car lurches. It is quite a big lurch, if you have not noticed it, you don't have it.
-Andrew
Old May 7th, 2003, 01:51 PM
GTmini's Avatar
Local Time: 01:29 PM
United States View GTmini's Dark Silver & Body Color 1st Gen MINI Cooper S Profile
yeah, I've got it, but I just attributed it to the nature of the beast. Now I somes clutch before then (more breake dust/wear though!) or I think by now I've just started subconsciously ignoring it.
Old May 7th, 2003, 03:52 PM
Martin L's Avatar
MINI defector
Local Time: 09:29 PM
England Male View Martin L's Astro Black & Body Color 2nd Gen MINI Cooper Profile
Isn't that why you use the clutch
Idle is about 750-900, anything between there and around 2000 needs a fettling to the clutch to avoid the "kangerooing" effect.
To be perfectly honest you're in the wrong gear if you're letting your revs go below 2000rpm and not using the clutch
Is this your first "stick" shift?????
MINI, RX8 and MX5 - Done those............. It's now TTime
Unofficial MINI2.com bean counter
Old May 7th, 2003, 05:48 PM
L8 Apex
Guest
Posts: n/a
No, I've been driving a stick since I was 15, and I am now 18. I even know how to drive a non-syncronized 'dog tooth' transmission. The problem is this...When making right turns (left for you brits) you almost have to go below 2k rpm in second gear unless you want your passengers to start looking for something to hold on to. The other option is to downshift to first, but I would like to avoid first gear downshifts. So basically, if I am making a right turn, I will go below 2k rpm, and then it lurches. Under 2k rpm it is definently not lugging and when I get on the gas in second, the car pulls smoothly, but not so stongly. There is just this big lurch at 2k rpm, never below, never above. I know that it is electronics, but I was just wondering if anyone else had this problem.
-Andrew
Old May 8th, 2003, 01:37 AM
RickB's Avatar
Local Time: 08:29 PM
United States View RickB's Dark Silver & Black 1st Gen MINI Cooper S Profile
I declutch before the engine gets down to 2000, and I often do so even if I'm not going to shift, if I'm turning, so I rarely feel the lurch, but I know it is there.
Best RPM? grey S First Generation MINI Cooper S 23 Jan 3rd, 2005 08:48 PM
RPM vs. TE 37 CNred Wheels, Tyres & Brakes 0 Sep 3rd, 2004 06:10 AM
A REAL BMW rep called me about CD 36 & the stumble/lurch/bog in CVT models Rwatts4mini First Generation Faults & Fixes 17 Jan 2nd, 2004 12:15 PM
DSC-related (?) acceleration lurch dpms2 First Generation Faults & Fixes 4 May 28th, 2003 11:09 PM
What rpm do you like to cruise at? gowest First Generation MINI Cooper S 10 Jan 2nd, 2003 11:54 AM
