I purchased an 04 s yesterday and the previous owner mentioned that there may be a problem with the window. What I noticed was that when you close the passenger door the window won't go up the 1/4"...does anyone know what may be the issue...The previous owner mentioned they replaced the window motor a few years ago, but that everything was working fine...just that it won't go up when you close the door.
Im new to Mini Coopers as I Have driven an old Ford for the last few years....any help or advise is greatly appreciated.
That's the one good thing about Minis - they're so unreliable, you can guarantee tons of people have had the same problem before so finding a fix is easy
I must have neglected mine then
In 20 years of driving I've only ever had to be towed home twice - BOTH times in the Mini, which I've only had 4 years.
TBH I'd never have expected that parts that failed to do so without a crystal ball
I blame the previous owner John! None of my MINI's have seen a tow truck (yet) except the BL one which I blew up. I don't have any faith in the dealer network as I've had 2 cars in for repair (under warranty) and once they failed to repair it and charged me an extra £315! then quoted me nearly a grand to actually fix it after I pointed out the problem. I fixed it myself for £55 and my labour was free :big_grin:
I doubt any previous owner could have made the ignition switch suddenly stop working leaving me stranded ?
And the radiator leak... Maybe if the coolant hadn't been changed, but it had as it wasn't BMW colour.
Totally agree with dealerships, their work is just shoddy and massively overpriced ?
Thanks and you are correct Google isn't broken...however I have tried all those helpful tips and tricks I found on Google and none work...hence the reason I turned to the forum. I even tried the good ole bang above the speaker trick...any other ideas?
Pretty sure it's a micoswitch in the door lock as mechanically that's the only way it can do this
Sent from my iPhone using Tapatalk
Related Threads
MINI Cooper Forum
3.6M posts
159.9K members
Since 2001
