Warning lights!!! Help please - MINI Cooper Forum
 4Likes
  • 2 Post By k3fus
  • 2 Post By SeanC
post #1 of 10 (permalink) Old Jan 16th, 2017, 02:06 PM Thread Starter
Local Time: 10:59 PM
Garage
So not sure if this is the right place i have an 01 mini one and i have warning lights on and i can only assume there is a wiring issue. The abs and handbrake warning lights dont go off ever and neither do my tire pressure or my airbag warning lights and on top of all this there is no lights that come on at all on my tacho.
Any help here would be great ill try and put pics up now if not might be later
Cheers for any help in advance!
ID:	209986   Click image for larger version
BeardyMini is offline
post #2 of 10 (permalink) Old Jan 16th, 2017, 08:00 PM
Quoted: 81 Post(s)
BCM Needs checking for water ingress, to change it the new one needs coding to the car.
SeanC and BeardyMini like this.
k3fus is offline
The Following 2 Users Say Thank You to k3fus For This Useful Post:
post #3 of 10 (permalink) Old Jan 16th, 2017, 09:41 PM
Quoted: 742 Post(s)
Spot on the dot @k3fus
The BCM is located in the drivers footwell and the early cars like yours BeardyMini didn't have covers on them to help prevent water ingress from hitting them. You will probably find that your car has had a replacement windscreen at some point and the leak has started from there on! A quick way to determine if it is the BCM is to hook a diagnostic reader up and if the reader can't clear the codes nor can it even see the BCM then there lies your fault. The bad news is a new BCM from mini is just over 500 fitted or there abouts!
k3fus and BeardyMini like this.
SeanC is online now
post #4 of 10 (permalink) Old Jan 20th, 2017, 05:06 PM Thread Starter
Garage
cheers for the help! looks like ill be paying out more than i payed for the car!
shame i might have too scrap it.
post #5 of 10 (permalink) Old Feb 15th, 2017, 04:40 PM Thread Starter
Garage
so after buying another mini im going to attempt to keep this broken one on the road as pointed out above i have a BCM issue so i had a look around on ebay and found this (see attachments) cant post links yet but it seems to be what id need for this car my question is can this just be fitted directly into the car without any coding or would i still need too make a trip to mini?
its same model and year as my car so im assuming part numbers would be the same :S
not going to buy it unless someone know 100% if it would work or be easier than having new one fitted by mini
post #6 of 10 (permalink) Old Feb 15th, 2017, 04:57 PM
Quoted: 742 Post(s)
In theory it should work but whether it actually solves the problem is another. If it's cheap enough it's worth a punt I'd say as a BCM at mini is around 500 and whatever else if it needs broken wires fixed!
SeanC is online now
post #7 of 10 (permalink) Old Feb 15th, 2017, 05:02 PM Thread Starter
Garage
well at 115 not cheap but lot cheaper than mini would be cheers bud
post #8 of 10 (permalink) Old Feb 15th, 2017, 06:03 PM
Quoted: 742 Post(s)
tbh Beardy, I'd probably take a stab at that mate and see how it goes.
SeanC is online now
post #9 of 10 (permalink) Old Feb 20th, 2017, 11:42 AM Thread Starter
Garage
so i havent bought the stuff pictured above as i realized it didnt have a bcm with it... was wondering if i could just buy a bcm from same model same year mini as mine and switch them? or would i need everything from the same car?
post #10 of 10 (permalink) Old Feb 20th, 2017, 04:18 PM
Quoted: 742 Post(s)
The BCM is coded to the ecu
SeanC is online now
ABS Warning Lights, // Traction Control Light// Hillstart Assist Failure Mininewgirl Second Generation Faults & Fixes 0 Sep 12th, 2016 10:14 AM
Help! Asc/ seatbelt / cruise control. Warning lights Billysevern7 First Generation Faults & Fixes 0 Mar 19th, 2015 07:29 PM
Multiple Warning Lights! MandyD Second Generation Faults & Fixes 5 Nov 19th, 2014 07:24 AM
Warning lights lit again! minidriver_one First Generation MINI One D 1 Nov 23rd, 2013 05:53 PM
Multiple warning lights on start up Sparkling Silver Second Generation Faults & Fixes 8 Oct 19th, 2012 03:48 PM
