headlight adjustment - MINI Cooper Forum
post #1 of 5 (permalink) Old Feb 14th, 2017, 02:09 AM Thread Starter
Local Time: 05:59 PM
Quoted: 5 Post(s)
United States Male
Hey all:
Which direction should the adjusting screw be turned, clock-wise or counter clock to elevate the dip beam. there was a thread on here a year or so ago, but I cant find it now.
Fritz
2005 Chili R52 "Jane"
pencarrow is offline
post #2 of 5 (permalink) Old Feb 14th, 2017, 04:59 PM Thread Starter
Quoted: 5 Post(s)
United States Male
No one ????????????
post #3 of 5 (permalink) Old Feb 14th, 2017, 07:11 PM
Local Time: 10:59 PM
Quoted: 742 Post(s)
Line the car up facing a wall with the headlights on and leveller set to zero and mark the top of the beam with a piece of chalk then adjust the screw one turn at a time (count the turns and keep a note of them so you can go back if need be) then check the light beam against the chalk mark (make sure that your hood is closed properly when checking) That new height difference will tell you what way you want to go. The same idea applies for the left to right adjustment too. This is how us oldies used to adjust our lights back in the day. Now I just get the lads at my local garage to adjust them if needed when the car get's it yearly MOT check.
SeanC is online now
post #4 of 5 (permalink) Old Feb 14th, 2017, 11:14 PM Thread Starter
Quoted: 5 Post(s)
United States Male
Thanks SeanC:
I have used your method on other cars before. The reason for asking is if the adjusting screws are at their max limit they will brake, most times can't be fixed.
Fritz
post #5 of 5 (permalink) Old Feb 14th, 2017, 11:20 PM
Quoted: 742 Post(s)
No worries buddy
SeanC is online now
Bi-Xenon Headlight adjustment ? Steven Blanc Maintenance & MINI Care 2 Sep 2nd, 2016 04:01 PM
Flickering headlight 2007 MCS simonc3817 General Discussion 0 Sep 14th, 2015 09:59 AM
Xenon headlight problem, please help! bseado General Discussion 2 Jul 23rd, 2015 10:50 PM
Gap around Headlight - Xenon's with Black Trim ring dealmaker33 MINI Countryman 2 May 6th, 2014 06:36 PM
R53 Self Adjust headlight grinding and not lifting williamtell First Generation Faults & Fixes 0 Jul 29th, 2013 11:52 AM
