This isn't a rear main seal leak!! - MINI Cooper Forum
 1Likes
  • 1 Post By Milpol
post #1 of 2 (permalink) Old Feb 15th, 2017, 07:38 AM Thread Starter
Local Time: 02:01 PM
Hi team
1st post new member mini fan.
I have a 2004 cooper S jcw 6 speed that has been costing some money lately.
I had a non starter that a tap of the fuel pump while turning over got me home ( replaced that and filter)
I had a right hand side vibration that was a drive shaft and lower rear bush replacement
And now just after replacing the drive shaft I had a heap of oil coming from the bellhousing. Naturally I thought case pressure and rear main seal however further investigation showed a different story
It appears that the bolt in the shift fork assembly has broken where the threads stop and proceeded to smash a hole into the gearbox where the diff is. The clutch housing is a mess and I am looking for advice if it is a common problem and what is the best fix??
Thanks for any help
( how do I add a photo for you) hmmm
alxcar is offline
post #2 of 2 (permalink) Old Feb 15th, 2017, 09:14 AM
Local Time: 12:01 AM
Quoted: 179 Post(s)
Australia Male
Garage
Not a common problem as I have the same issue on my R53 where a pin hole (emphasis on pinhole) was created when the throwout bearing shattered. The bolt most likely at some stage was damaged on a prior service or may have been faulty. Your up for a rebuilt gearbox and you wont get any money off as a core exchange due to the damage to the casing. I have just spent $2k on a SH Gearbox which I intend to swap out soon as I fear that my current leak may be from the alloy weld repair that may have failed. Alloy weld repairs are hit or miss due to hidden stress cracks that may open up when welding or afterwards and are very difficult to prevent. You will need to check for oil contamination on the clutch plate and while your at it, wear to the flywheel and any swarf/debris that may have entered. The good news is, its the perfect time to check and replace the rear main seal to the engine and if your clutch/flywheel is contaminated or damaged, a low cost option is the Valeo single mass flywheel and clutch kit (cheaper than just the OEM flywheel alone). Modmini on YouTube has a video on the Valeo unit and also a good DIY on swapping it all out.
To add a photo, you need a few more posts before you can upload.
SeanC likes this.
Milpol is offline
2005 R53 oil leak from rear of engine block richdean123 First Generation MINI Cooper S 1 Feb 21st, 2017 03:42 PM
R53 Mini Cooper S oil leak from rear of engine block richdean123 First Generation Faults & Fixes 6 Dec 11th, 2015 05:41 PM
Use of "engine stop leak" oil additive to cure crank main seal oil leak ? pfspeeddemon First Generation MINI Cooper S 12 Feb 10th, 2015 07:31 PM
Water leak from rear view mirror (and surrounding area)? edwardtobia First Generation Faults & Fixes 3 Nov 29th, 2013 07:24 AM
Crank sensor seal oil leak idea Shanos Maintenance & MINI Care 5 Feb 6th, 2013 06:56 PM
