engine power failure- EML and oil lamp warnings lit - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old May 31st, 2003, 02:37 AM
Local Time: 03:14 PM
Sweden View Allyson's Pure Silver & Black 1st Gen MINI Cooper Profile
Sweden engine power failure- EML and oil lamp warnings lit
My 2002 Mini pooped out on the motorway today. Soon after morning start, the EML and oil lamp came on and acceleration felt strange- I stopped and check the oil level ( it was normal) and thought it was just reactions from a cold start after two days of unuse. I restarted and all the warning lamps went off after a few seconds. Then after a 45 minute drive and a fillup, the motor suddenly lost power on the motorway in 5th gear on a slight incline.( maybe five minutes after I had stopped at the gas station) I geared down to fourth and lost even more speed and power, and noticed those two same warning lights on. Took the nearest exit driving slowly in the emergency lane ( my warning blinkers worked!), found a parking lot downhill from the freeway exit ( coasting) and was towed by the Mini service after an hour's wait. It's a semi- holiday here in Sweden so the workshop is closed till Monday. They lent me a VW Golf to drive! It's not the same
Old May 31st, 2003, 02:41 PM
Local Time: 05:14 AM
United States View retroom's Liquid Yellow & White 1st Gen MINI Cooper Profile
Sounds like the problem is caused by a bad engine wiring harness and/or defective throttle body.
If either is diagnosed bad it needs to be replaced.
retroom
2003 MC,LY/W, sport package, wht wheels, cruise, chrome, Kaleido cloth/black, OB computer
Old May 31st, 2003, 03:04 PM
swamos's Avatar
MINI Traitor
Send a message via Skype™ to swamos
Local Time: 11:14 PM
Australia View swamos's Electric Blue & White 1st Gen MINI Cooper S Profile
Maybe the engine has an auto shutdown on low oil pressure?? If that is the case, then maybe you've got a failed oil pump, or sensor...
Let's hope not
Old May 31st, 2003, 04:02 PM
Thanks for the comments- will keep you posted. I've heard when the EML light goes on that the motor has a self-limiting power supply. I hope it's nothing too serious- I was embarrassed that my new Mini was being demeaned by being hauled off publically and sad that it is sick.
Old Jun 4th, 2003, 02:55 AM
It was a defective throttle body and my Mini works beautifully again. It's such relief after driving this Golf. No problems about the replacement parts covered by the warranty either. A very friendly dealer in Solna, Sweden too.
Old Jun 4th, 2003, 03:46 AM
minitech's Avatar
Let's Motor...
Send a message via MSN to minitech
Local Time: 08:14 AM
United States View minitech's Classified Ads
DIY
the engine harness in most of the minis as of now might be defective and might bring the car to an idle or turn the oil light on and so on.the micro pin connection mini is using are faults and poor. as of a low oil shut down they dont use that.i hope they will fix it....good luck
let's motor
Old Jun 4th, 2003, 03:59 PM
Local Time: 02:14 PM
United Kingdom View crooksm's British Racing Green & White 1st Gen MINI Cooper Profile
United-Kingdom Again?
The same thing happened to me about two weeks ago and the dealer replaced the throttle body.
However...I started the car this morning and the engine warning light came on and stayed on until after I drove the car to work (about 10 miles). It was different to the previous symptoms though as the EML light did not come on neither did I experience a loss of power.
Has this happened to anyone else??
What do you think this may mean?
Old Jun 4th, 2003, 08:50 PM
HarryHBMCC's Avatar
Canada Male View HarryHBMCC's Laser Blue & Black 2nd Gen MINI Cooper S Convertible Profile
Unfortunately, it means you have to go back to your dealer. Could be they didn't fix the real problem or could be coincidence, an entirely new problem.
Harry
Old Jul 19th, 2003, 04:03 PM
It me again six weeks later and my 2002, 5 speed failed again. The engine warning light came on again two days ago after a failed ignition, but went out after a third restart. Today after an acceleration to pass, the EML and engine arning lights came back on. Every time I lightened up on the gas pedal my car would hiccup with bad acceration. Drove directly to MINI repair and got another rental replacement ( Audi A3) Maybe this time they need to change the wiring harness??
Old Jul 20th, 2003, 08:42 PM
Yep - sounds like it. When it happened to me first time round they replaced just the throttle body. Then two weeks later it happened again and they replaced the wiring harness. It's been six weeks now and, touch wood, everythings been fine.
Hope it stays that way
Old Jul 20th, 2003, 09:01 PM
Hobbe's Avatar
Absolut MINI
Sweden
Allyson,
if youŽd like to find MINI people in Sweden try:
http://www.coopersweden.se/
WeŽre a few in the Stockholm area already.
MCS WORKS GP 0120
WWW.BMWSC.COM
Old Jul 21st, 2003, 04:30 AM
I'll have a look- tack!!
Old Aug 7th, 2003, 01:30 PM
Well here I am again- having had my MINI in the repair shop for nearly 2 weeks- they replaced the throttle body for the third time and I ( refering to this forum) said they should check the engine wiring harness as well. They instead diagnosed a problem with the throttle housing and have replaced this part after its arrival from Germany. I feel when I release the gas in 2nd and 3rd gear a vague hiccuping feeling, but maybe I am over sensitive at this point. ( My MINI has had five visits for repairs since Dec 2002) Today my rear hatch wouldn't lock either and getting no sound advice from the dealers on the phone, I found a solution on this site. ( Open hatch, push wing buttom on remote to reset locking ) Thanks for existing my fellow MINI owners!!!
Old Aug 7th, 2003, 02:08 PM
bg1229's Avatar
Local Time: 09:14 AM
United States View bg1229's British Racing Green & White 1st Gen MINI Cooper Profile
ALY,SO SORRY TO HEAR ABOUT YOUR PROBLEMS,I CANT SPEAK FOR THE BOOT ISSUES AND I HOPE I AM NOT BEING REMISS HERE BUT I CAN'T UNDERSTAND WHY THEY WON'T REPLACE THE WIRING HARNESS? I HAD THE SAME PROBLEM AT 7000 MILES AND RECEIVED THE SAME ADVICE ABOUT THE W HARNESS BY OUR BUDDIES HEAR ON THIS SITE.I NOW AM HAPPILY TROUBLE FREE.BUT ENOUGH OF THAT.WHEN YOUR DEALER PERFORMS THE DIAGNOSTIC TEST,I WOULD IMAGINE THEY WOULD SEE THE HARNESS ISSUE PERHAPS THE PROBLEM LIES WITH THE DEALER,WHO SHOULD,IF ANYTHING BE BENDING OVER BACKWARDS FOR YOU.I REALLY DO HOPE YOU GET THIS ALL SORTED OUT SOON AND CAN BEGIN REALLY ENJOYING YOUR CAR
  #15 (permalink)
Old Aug 10th, 2003, 05:10 AM
Australia View Neeshil's Pure Silver & Black 1st Gen MINI Cooper Profile
Yeah I had my EML light come on when i was on the motorway. There was no lane to pull over. (grrr!) Ended up being the wiring harness which the replaced. It is a 'known' issue with BMW's and Mini's (my mum had same problem in her 318i and my friend in his 325ci!)
Why haven't they done a recall?
Mini Cooper : EML/New wiring loom. Down on power zUgan First Generation Faults & Fixes 2 Apr 3rd, 2007 05:47 AM
Bizarre Engine & EML Failure Mongomaniac First Generation Faults & Fixes 2 Nov 20th, 2006 10:45 AM
2006 Cooper - CVT Auto Transmission Failure #2 & Power Steering Pump Failure - Why??? Joe Z First Generation Faults & Fixes 17 Feb 18th, 2006 12:33 AM
EML Light, engine failure, my mini stopped on highway! Neeshil First Generation Faults & Fixes 13 Jul 31st, 2003 11:38 PM
EML & Flat Lamp Lit Robert Moreau First Generation Faults & Fixes 6 Jul 14th, 2003 03:21 AM
