Xenon Headlight Replacement - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jun 4th, 2003, 07:00 AM
Send a message via AIM to Subiklim
Local Time: 01:15 PM
United States View Subiklim's British Racing Green & Black 1st Gen MINI Cooper S Profile
One of my xenon headlights went out, and they replaced it under warranty. However when they replaced it the replaced everything, the housing, ballast, etc. When the warranty runs out will I have to pay to replace everything, not just the bulb? TIA
Old Jun 4th, 2003, 10:12 AM
RUKnight's Avatar
Send a message via AIM to RUKnight
United States View RUKnight's Chili Red & Black 1st Gen MINI Cooper S Profile
No just the bulbs should be replaceable, but they are expensive, like over $150.00 per bulb. You may have had a short in your headlight so they did it as a pre-caution
Mike
05 CR MCS on order
Old Jun 4th, 2003, 11:12 AM
BruceK's Avatar
Moderator & Sponsor
Local Time: 07:15 AM
Re: Xenon Headlight Replacement
This reminds me that I had one of my car's xenons go out temporarily.
It happened when I was adjusting my MINI's headlights the old fashioned, manual way (park about 30 feet from a wall on level ground, notice where the headlight patterns fall on the wall, turn off the headlights, open the hood and make an adjustment up or down, left or right, shut the hood, turn on the lights and repeat as necessary). To do this I was turning the headlights on after each adjustment to see the result and then off to make further adjustments. (There was no way that I would be messing with them when they are powered up because of the tremendously high voltages involved. Just too dangerous).
Anyway, with all the cycling of the xenon lights on and off over a short period of time, one of my xenons just failed to light. It flickered a little much like a fluorescent bulb at home sometimes fails to light up. I was upset and was planning a trip to the dealer to sort it out.
But I decided to give the headlights a rest of 5 minutes and then tried them again. Presto! They both lit up as normal. It's been 8 months since that event, and both of the xenons on my MINI have never failed to light since that single time.
Old Jun 4th, 2003, 09:28 PM
motorer's Avatar
Local Time: 06:15 AM
United States View motorer's Dark Silver & White 1st Gen MINI Cooper S Profile
Re: Re: Xenon Headlight Replacement
<snip>
Read the manual. If I remember correctly it warns against turning the xenons on for short intervals.
Also...manually adjusting your xenons? I thought they self-corrected and stayed pointed at the ground...
Off motorin' -
Jeff
http://66.122.46.82/~minimotorer/
Old Jun 4th, 2003, 09:37 PM
Dan Harmon's Avatar
Local Time: 08:15 AM
United States View Dan Harmon's Indi Blue & White 1st Gen MINI Cooper Profile
Hi Mike I have a question about the xenon Head lights. I have the regular head lights in my car now. If wanted to could I Just change the over to the xenon Bulbs? Could I just get the the Night time bulbs and not teh day light bulbs?? thanks DAN
Dan Harmon
Old Jun 5th, 2003, 12:22 AM
ChrisD's Avatar
United Kingdom View ChrisD's Pure Silver & Black 1st Gen MINI Cooper Profile
The Xenon headlamps run at about 15000 volts on startup, so no you cannot just swap them over.
Plus you will need the controller and ballast and the automatic headlamp level adjuster
Old Jun 5th, 2003, 09:32 AM
BruceK's Avatar
Moderator & Sponsor
Re: Re: Re: Xenon Headlight Replacement
Yes, I knew they shouldn't be turned on and off quickly, but it was taking me at least a minute between cycles. I thought that was enough, but apparently not.
All MINI headlights can be manually adjusted. There are two back screws on the back of each headlamp housing. One controls up and down, the other right and left. It's true the xenons are self-leveling depending upon the load of passengers/cargo in the car. However, it is through the adjustments that you can tell the xenons what "level" means, then they will work to maintain that level. In the case of my car, for some reason the headlights came from the factory aimed way too low. I carefully adjusted up them to provide more light on the road ahead of me - I was very careful to ensure I did not raise the pattern so high as to glare at oncoming drivers.
Old Jun 5th, 2003, 06:09 PM
Minty's Avatar
Man in the know!
Send a message via MSN to Minty
it is unusual for a Xenon bulb to go. It would more than likely be the Control unit.
MINI-3 @ Cotswold MINI | BMW-four @ Cotswold BMW | E-Mail Me | Minty - Part of the IT Crowd!
Old Feb 8th, 2007, 05:00 AM
luVlee's Avatar
MINI2 Lover
Send a message via MSN to luVlee
Canada Male
is there a DIY on replacing the HID bulbs? I want to change my HID bulbs to a more blue ones. What's the bulb I need? Im thinking maybe 6000k.
Old Feb 9th, 2007, 12:28 AM
Canada
Xenon Problem
I have had on a number of occasions one or the other not coming on. After 4 or 5 times turning them on and off it works. I bought a new bulb at the $150.00 and tried that but the problem still is there. I looked for a relay with negative results. Would this be the ballast or controller? How much for either of these?
Evan...
Xenon Headlight Upgrade emu_p First Generation MINI Cooper 16 Jun 18th, 2007 12:10 AM
Headlight Washers only on the Xenon C. Crampton First Generation MINI Exterior 3 Sep 28th, 2004 03:47 AM
Xenon Headlight Upgrade caminifan First Generation MINI Exterior 1 May 28th, 2004 12:58 AM
HELP: xenon headlight removal Sharkey Maintenance & MINI Care 0 Nov 5th, 2003 03:59 PM
XENON HEADLIGHT, MINIUSA please read aerodragon General Discussion 20 May 12th, 2002 09:30 PM
