Mini Cooper s super charger - MINI Cooper Forum
 2Likes
  • 1 Post By NigelK
  • 1 Post By anish1993
post #1 of 7 (permalink) Old Apr 20th, 2017, 03:49 PM Thread Starter
Local Time: 03:32 PM
Hi kind of new to this whole thing do have no idea if I have posted in the correct bit but had to try find out what was wrong if there actually is with my car. I seen a YouTube video of the same mark model year ect as mine ( 2003 plate Cooper s ) An I noticed that the whine of the super charger was more loud An noticeable then mine. Mine is very quiet and it got me thinking if there is anything wrong with mine ? The power still seems to be there An you can hear the super charger but not as much and clear as ones on videos I have seen, mine seems to be very quiet. Anyone who can help me would be appreciated.
JonSnow_93 is offline
post #2 of 7 (permalink) Old Apr 20th, 2017, 04:22 PM
Moderator
minione2002's Avatar
Quoted: 479 Post(s)
If there was something wrong with your supercharger it wouldn't be quiet.
It would be grinding/grumbling .
Most minis on upube have modded engines i:e
davef filter
15% supercharger reduction pulley
bigger intercooler
etc
all of which make the whine louder.
minione2002 is offline
post #3 of 7 (permalink) Old Apr 20th, 2017, 08:30 PM
WindyG's Avatar
Quoted: 6 Post(s)
I doubt there is anything wrong, you most likely have a standard air filter, anything aftermarket will increase the the SC whine.
WindyG is offline
post #4 of 7 (permalink) Old Apr 20th, 2017, 09:41 PM
Quoted: 90 Post(s)
Exactly as posted. I've put an Orranje Stealth CAI - Cold Air Intake on mine. Which I believe is the same as the DaveF referenced by Minione above. Pulley is still standard on mine. Changing (reducing) the pulley that drives the the supercharger (SC) makes the SC go faster at the same engine revs which therefore a) pumps more charge (the air and fuel that makes the bang that drives the piston) into the engine b) makes more whine.
Here is a link to KAV Motorsport who are one of the main suppliers of modified pulleys:
Mini Cooper S supercharger pulley
Back to whine. If you have a standard panel filter you won't hear the whine - much. With a CAI you will, much louder and nice if you like that kind of thing, which I for one, do.
Why is this I hear you ask. A CAI lets the intake side breath better. Most of them, inc. the Orranje CAI, require you to cut a larger hole in the plastic 'bulkhead' panel at the back of the engine so it sucks air in from there. Now it so happens that that is where the car gets air for the cabin ventilation system - the black plastic grills in front of the windscreen, in this case the one on the passenger side. So now the CAI is sucking air from there AND the cabin air is coming in through the same space. Therefore the whine of the SC slurping air through there can be heard much more loudly inside the cabin. And there you have it.
If you put said pulley on you will get even more whine.
Link to the Orranje Stealth CAI:
https://orranje.co.uk/product/orranj...air-intake-kit
You can go up to a 15% pulley without needing to go to a larger intercooler (IC). If you go 17% you need to sort the IC. That is because the more the SC compresses the air the hotter it gets (hotter air = bad). Therefore a larger IC will lower the temp of the air being pumped by the SC into the engine. And you would then need to remap the ECU to deal with it all.
The Orranje is very reasonable at 125. There are numbers of other CAIs which are much more money. One of the things I like about the Orranje, apart from the excellent whine, is that when you look in the engine bay you can't see it is fitted. Looks as though you still have the standard panel filter set up. Hence the 'Stealth' moniker.
Pic of it fitted and the panel to it's right that has the bigger hole cut in it - that you can't see.
Hope this helps.
minione2002 likes this.
NigelK is offline
post #5 of 7 (permalink) Old Apr 21st, 2017, 09:41 AM Thread Starter
Just to get a better understanding. I went out today And when I accelerate the power is there no doubt about that you can still hear the super charger working. The only way I can describe the noise as is rough. There's no clanging banging screatching noises it just sounds abit I'll. I'm due a oil An filter change anyway which I was going to do this weekend could this be potentially why ?
post #6 of 7 (permalink) Old Apr 21st, 2017, 02:12 PM
anish1993's Avatar
Quoted: 47 Post(s)
Loool i think the quieter the better.
You shud be worried if yours whines alot
Sent from my iPhone using Tapatalk
NigelK likes this.
anish1993 is offline
post #7 of 7 (permalink) Old Apr 22nd, 2017, 10:21 PM
Quoted: 90 Post(s)
Jon, heads up on the lubrication of the supercharger. It has its own oil resevoir. Unlike a turbo, it isn't lubricated by the circulating engine oil. So doing the engine oil and filter won't affect the SC. There is no service or top up interval for the supercharger oil. BMW say it is 'for life'. It can use its oil or need it changing at high miles.
It needs removing to deal with it and it is a difficult job and a lot of work to get at it and put it back. If you have a minute flick through this guide. As you will see, the guy has the whole front off the car, rads and all, and THEN has to do a LOAD of work to get it out. There is a reason for that and it is not a nice one!!
https://www.youtube.com/watch?v=FA9QIXtBGuM
NigelK is offline
BMW Mini R50, R52, R53 Cooper S Carbon fiber Exterior Side Grilles nvd MINI2 Classifieds 0 Mar 22nd, 2017 09:49 AM
2010 Mini Cooper S Review Richard735 General Discussion 6 Jan 3rd, 2016 02:00 PM
Mini Cooper discounts Mini novice Welcome New Members 0 Aug 31st, 2014 10:28 AM
Mini Cooper S vs Mini Cooper S JCW twc1001 First Generation MINI Cooper S 7 Feb 4th, 2013 10:18 PM
