| At a track day I was at last week the flat tire warning light was sometimes flashing and somwetimes on steady even although the tires were all at the same pressure. At different times I also had the airbag light come on. Seems like the workout was too much for my poor baby! I would be a lttle more sensitive to the EML light but there are so many things - fuel door not properly closed for example - that can cause it to light up. I would feel OK driving as long as it didn't reoccur. aka KWKSLVR Member: Southern Ontario MINI Club BMW Club of Canada - Trillium Chapter |
| Mine did the same thing one night for about an hour. I attributed my problem though to a period of frequent (30+) stop/off/start/unlock combinations as I drove around picking stuff up. Hasn't happened since. Dave Gotten anything useful from MINI2? How about giving a little something back? '03 MCS BRG/W Anthracite Pkg 1,2,3 |
| My tire warning light has come on a few times. The tires are fine. If I shut down the engine and restart, the light goes off....I guess I have to have service look at it.... |
| I freaked the car out last winter in snow. I was reversing in snow and not coming to a full stop before moving forward, I put the car into first and let the clutch out whilst reversing. the car was moving backward with the front wheels rotating forwards. All of a sudden every warning lite came on. Holy crap! Since then I make sure that all wheels are turning in the same direction. Charles BRG/W MCS |
| I have had my Mini for about 3 weeks now and have the run flat and the light above the EML (the triangle with the counter-clockwise arrow - can't figure out the name from the manual). Both times I have stopped, turned off the ignition and checked all tires which are fine. When I start my Mini again the lights are off. Am planning to ask dealer about problem. |
There are a few threads buried in here about this problem. Had my 03 MCS in for service for a leaking sunroof among other things and asked them again about this problem as it happens fairly often. They said MINI is working on a software fix for this (supposedly within the next month) Your dealer should know this is a MINI-wide problem. If not, just print a few of these threads out. By the way, the light you're referencing with the triangle is the Dynamic Stability Control light. 2003 Indi Blue S with White Roof White Bonnet Stripes Premium/Sport(with 16"s)/Cold Park Assist 6 MONTHS OF WAITING IS OVER!!! |
| engine power failure- EML and oil lamp warnings lit | Allyson | First Generation Faults & Fixes | 24 | Jul 16th, 2009 04:08 AM |
| Engine & EML Light | Fabio | First Generation Faults & Fixes | 34 | Jul 16th, 2009 03:44 AM |
| Bizarre Engine & EML Failure | Mongomaniac | First Generation Faults & Fixes | 2 | Nov 20th, 2006 10:45 AM |
| EML & Engine light keep coming on, Help! | venox22 | First Generation MINI Cooper S | 2 | Jul 21st, 2005 04:53 AM |
| 2 Genesis Dual Mono amps covered & lit at last! | Bianchiboy | First Generation Interior & Ice | 4 | Mar 26th, 2004 07:57 PM |
