Run flat indicator - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jul 17th, 2003, 01:36 PM
Local Time: 01:23 PM
Run flat indicator
Has anyone had problems with their run flat indicator on MCS....?
At weekend when it was very hot my warning light came on to suggest that i had a flat but when i spoke to mini emergency helpline they suggested it was due to the very hot weekend temperatures ...?
It has since been fine but only yesterday it started to flash again.
Has anyone else had this problem and if so is it just a question of air temp/lack of presseure in the tyres ..?
Matt
Hartge MCS.
Old Jul 17th, 2003, 02:01 PM
Polmear's Avatar
Local Time: 09:23 AM
My flat-tire monitor flashed a couple of weeks ago, turned out that one tire was 2psi low. No problems, though; the reset was easy, just like the manual states.
Cheers!
Old Jul 19th, 2003, 09:44 PM
Local Time: 08:23 AM
United States Male View Johnson's Indi Blue & White 1st Gen MINI Cooper Profile
I had this happen on a MC a few weeks ago. Pressures were all the same, no variation at all. Reset and had dealer check out. No fault codes and nothing they could find. You might do a search on this site. There are other threads discussing this and an apparently related DSC light problem.
Old Jul 22nd, 2003, 05:39 PM
Local Time: 06:23 AM
Philippines
Try this link. It might help.
http://www.mini2.com/forum/first-generation-faults-fixes/9833-dynamic-stability-control-tire-pressure-alert-showing-malfunction.html
Battleship Grey Metallic/B/B MCS
with every option known to man/BMW
less CD changer and NO car problems.
Old Jul 23rd, 2003, 09:40 PM
Just some additional info..
When you adjust youre tyre pressures(done when tyres are cold)you carry out recalibration of the RPA/RDC/DDS (Call it what you may) By turning the ignition on fully but not starting the engine,press and hold the RDC button in for approx 6-8 seconds until the warning light is displayed in the cluster which is in about 3-4 seconds,this then instructs the RDC System to adopt the current tyre pressues as the setpoint to monitor any loss of pressue to.
Depending on the driving style and conditions the learning process can take between 45 minutes and several hours to complete.
However the system is already armed for any loss in pressure after 10 minutes and can detect air pressure losses of approx 50%. As the calibration process continues the warning thresholds are decreased to 40% and then 30% , so it can detect smaller losses of pressure the more it carries out its learning process.
Hope this info helps
Run Flat Indicator? KenL Wheels, Tyres & Brakes 8 Nov 3rd, 2010 10:31 PM
Run flat indicator SoggyCornFlakes Wheels, Tyres & Brakes 2 Nov 13th, 2005 05:16 PM
Weird Run-Flat Indicator? punkeyfunky First Generation Faults & Fixes 1 Jul 8th, 2004 12:30 PM
Run Flat Tyre Indicator JTT Wheels, Tyres & Brakes 9 Mar 3rd, 2004 10:14 PM
Run-flat indicator CrazyPhil First Generation Faults & Fixes 8 Sep 10th, 2002 11:45 AM
