Stiff Reverse Gear Gate Hi all - I am posting this with a mounting sense of desperation, the problem is as follows: My wife finally got her dream car a Mini Cooper S but then dissaster! She cannot get it into reverse gear. The problem is with the safety gate the amount of force required to force the lever through the gate is just to much for her to manage. It is so bad she acually hurt her back trying to force it across. OK she is petite but by no means a whimp! We took it to the dealers and of course they say it is within normal specs. The Mini UK helpline say they have never heard of an incident where anyone has a similar problem. The question is is there anybody else out there who has the same problem? Even I find it incredible the ammount of force that is required, 21 lbs that is 20% of my missus body weight, to get the lever past the gate. If there is anyone who is having similar difficulties please let me know. Thanx Murray |
| Welcome to MINI2 ![]() Order a Whalen Shift Knob. The 0.51kg weight of the knob will make it easier to get past the gate and also make shifting smoother. Check out the following thread: http://www.mini2.com/forum/showthrea...threadid=34150 ![]() |
| Reverse isn't too stiff on mine, but it's been made considerably easier by investing in a heavier shift knob. I have the Whalen shift knob, the extra weight has made the shifts smoother. Paul, you have a Whalen don't you? Has your wife used it? |
| Mine is stiff too, wife couldn't get it into reverse either at first. My solution is to shove the stick all the way to the 5/6 gear plane, then swing the stick into the reverse gate. The extra momentum overcomes the gate with no problem. Once I showed my wife that trick she hasn't had any problems or complaints. -gb |
| Thanks for replies so far, comforting to know we are not alone, we have tried the whack it over using the 5/6th gear spring to assist but she still struggles. I will investigate the heavier gearknob but blimey it is a state of affairs when you have to resort to that sort of thing. I am waiting to speak to a BMW Regional Technical Manager on the subject and following that probably a lawyer!!!!!! |
| I sorta like stiff reverse gate springs. It's a lot more betta than downshifting into reverse at speed. We don't have any probs with the shifter gate. My technique is to slap the shifter ball to the left and push forward all in the motion. Battleship Grey Metallic/B/B MCS with every option known to man/BMW less CD changer and NO car problems. |
| I have noticed that after thrashing the car a few times it does ease the gearbox slightly. Just keep putting it in reverse loads and it *may* get a bit easier. One option would be to have Mini put less stiff springs (they may not do this). When we first got our Mini, the gearbox was a pain in the ass but its good now. Dave |
| I disagree, it was tested, a lot, and I think they got it right. I've 'crunched' into reverse a couple of times in Abis MINI One when reaching for sixth (whoops!) after driving my S all the time, but I've NEVER accidently slipped into reverse in the S when driving along! |
| Thanks again all for the feedback both plus and neg. I guess there are those who like the really stiff reverse gate but spare a thought for those who are not so muscled! I still think that they could design a better system with a lift up safety catch a la Vauxhall or similar. That would be foolproof, witness those who have done a cruncher with the current design; guess that should tell BMW that their current system is pants??? Mind you they know best for example how to programme engine management units. DOH! Any way were getting shut. Cheers all. |
| This is precisely the correct technique. Slap it. It doesn't require much of a slap. If your reverse gate is much stiffer than ours, there's something wrong with the shifter mechanism. In that case you should make the dealer fix it. This is something you shouldn't be shy about. Shifting is a major part of the MINI experience. '03 MCS, black / black, 16" Wheels |
| I was going to post concerning this very same issue with my new car, now 300 miles old - my hope was that it was that it would get a bit easier as the gearbox gets worn in. From what I read here, this sounds unlikely - I think I shall also ask my dealer about it. David 2003 Mini Cooper S - DS/B |
| We had a Cooper S on test drive for a weekend with a view to trading in our MCS. My wife could not engage reverse gear without great difficulty. We have decided not to go ahead with the swap for this very reason. I'm gutted! |
| Gear changing is stiff | dazo | First Generation MINI Tuning | 0 | Nov 15th, 2006 01:34 PM |
| Stiff gear box in 2002 S? | viness | First Generation MINI Cooper S | 1 | Jul 10th, 2006 12:43 PM |
| Reverse Gear | leightongray | First Generation MINI Cooper | 31 | Dec 30th, 2004 09:55 PM |
| reverse gear | den123 | First Generation Faults & Fixes | 4 | Aug 13th, 2003 11:42 AM |
| reverse gear | bo nydal | First Generation Faults & Fixes | 3 | Oct 16th, 2002 03:01 PM |
