| I think i know what u are talking aobut... i've heard it before... I think its gas... hahahahaha NO NO not that kinda gas... its petro... its when u hit the accelerator and the clutch is still down (disengaged) and its the gasoline whooshing around getting pumped up. Thats what i figured it was. |
| UCSDxB0i: I thought it might be the gas - it's done it again today, full tank - straight after filling up.... Hmmmm.... - noise is definately on the left hand side of the car at the front fire-wall (if you know what I mean)...... It must be loud outside too, as 2 people turned their heads.... Back to the dealership tomorrow..... (well, can't let mini get homesick now can I !!) |
| Hello, This problem has been reported on here several times before, I had a BMW press car that had this 'feature', it's like rushing or running water by the 'glovebox' area. It seems to only be cars with aircon that are affected, and it doesn't appear to cause any other problems, but it's not right. A search for gushing sound or rushing noice or a few other words like that 'running water' will probably dig up the old posts for you, and maybe find you a solution. Paul |
| Hummm left hand side... meaning drivers side or passenger side?? is yours a right hand drive or left? Well doenst matter... when i heard mine it was comming down the middle of the car like right under the shifter that area... and it did make that sound that u are talking about only when i gas it a tad and havent released the clutch enough for it to catch... i dont hear it anymore cuz i'm not new in driving clutch anymore hehe Report back what u find out tho. I'm interested to know. |
| My car had the same problem and eventually got quite loud every time I accelerated. It must be a known problem with BMW as although I don't know how it is fixed, I mentioned it when my car went in for some warranty work and it was fixed and has been fine since. |
| Know what you mean Yes I had this it seemed to come from the centre underneath the bonnet. I dismissed it until my fan came on and would not go off and the car overheated. Had to have a new water pump fitted! do not get it now. Hope this helps. |
| I've got two clues--one starts with "S" and the other one with "W" Give Up?It's probably either the Screenwash or the Windshield Washer Reservoir. The reservoir sits just outside the driver's footwell/dashboard area. If you have headlight washers then there's one on the O/S as well. The only other possibility is the fuel tank like UCSDxB0i already mentioned. I never heard sloshing from my fuel tank until I removed the back seats. Then I discovered the fuel sloshing was more prevalent when full than it was on a partially full tank. |
| No - definately not the screen wash (it's empty !) - and it was empty when the noise occured. It's more of a 'transfer of fluid' sound (gurgling, running from UK passenger side to the middle of the bonnet under the dash) Mind you, I haven't heard it for the last week - aircon I belive, as I haven't run it recently. |
| UJ on Liquid Yellow??? | d.griffiths | First Generation MINI One | 10 | Nov 5th, 2003 02:34 PM |
| Liquid gold | Keith | First Generation Faults & Fixes | 0 | Jun 22nd, 2003 09:40 PM |
| Liquid Yellow | alinnes | First Generation MINI Cooper S | 17 | Nov 12th, 2002 04:35 AM |
