Coolant level right on min level - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Aug 23rd, 2003, 09:41 PM
rainbowdreamer's Avatar
Local Time: 01:24 PM
Checked my May 03 Mini One coolant level and saw it was right on the min level. Is this normal? I remember checking it a few weeks ago and recall it was higher than this - but is this an expansion tank and does the level change?
Temp guage does not move from normal.
Rainbowdreamer
Cooper S Sidewalk
Old Aug 24th, 2003, 02:33 PM
MiniMinor's Avatar
3 new text messages from.
Send a message via MSN to MiniMinor
Local Time: 02:24 PM
England Male View MiniMinor's Hyper Blue & White 1st Gen MINI Cooper S Profile
When the engine on mine is cold the level is half way and when it is hot it reads just under the max mark which i think is about right.
Old Aug 24th, 2003, 04:06 PM
Rob.'s Avatar
My car was the same when new. Seemed to 'loose' a bit of fluid over the first few months. The level does change depending on temp. I just topped my header tank up to between min and max and it has been OK since. Just use clean tap water.
coolant level going down jksgoh First Generation Faults & Fixes 4 Apr 13th, 2007 12:47 PM
Coolant level ? fraujmj First Generation Faults & Fixes 3 Jan 27th, 2006 05:51 PM
coolant level - please help matt21 First Generation Faults & Fixes 3 Oct 22nd, 2004 04:25 PM
Coolant level newminimark First Generation Faults & Fixes 18 Oct 14th, 2003 07:55 PM
Coolant level. KenL First Generation Faults & Fixes 9 Nov 29th, 2002 06:02 AM
