Slipped ring - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Sep 4th, 2003, 02:52 PM
Local Time: 09:39 AM
England
Red face Slipped ring
Sounds painful. My Cooper has been in to the dealers today to have the 'steering click' looked at. I was told that the problem is a slipped ring. Does this mean a bearing? I know the bearing is a problem in the steering rack/column. Anyway, I hope it's nothing more serious than the bearing.
Old Sep 5th, 2003, 03:17 PM
England
The problem was with the coupler behind the steering wheel. Anyone know what that is!?
I don't know if it's just my imagination but the familiar clunk from 1st to 2nd seems to have disappeared. It didn't go in to have that seen to. Weird. Seems like the beast has been excorsised
Old Sep 5th, 2003, 06:20 PM
Local Time: 08:39 AM
Yes it is called an airbag slip ring.
It allows the power from the airbag control unit to flow through this and into a connector behind the wheel and then into the steering wheel.
Its the only way to get power to the drivers-steering wheel airbag if you think about it?
It basically a few wires that go into the slip ring and are curled up around the ring and come out into a connector inside the steering wheel assy itself and plug onto the airbag.
Hope this helps.
Old Sep 5th, 2003, 06:41 PM
England
Thanks for the explanation. Much appreciated.
Hope this helps.
Easter At the Ring s_and_m UK & Ireland Discussion & Event Planning 5 Apr 21st, 2006 03:12 AM
When should I ring Feline General Discussion 16 Jul 20th, 2004 03:24 PM
Return to the Ring s_and_m UK & Ireland Discussion & Event Planning 1034 Feb 12th, 2004 07:50 PM
