Help Emission Warning Light On.....? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Sep 19th, 2003, 04:59 PM
Local Time: 12:01 PM
Question Help Emission Warning Light On.....?
Had mine come on today...
Car still drives fine, I have the Hartge + Full Milltek System + CAT fitted 6mths ago..
I have it booked into the dealers the end of next week, any ideas.is the cat buggered ??
Is there anyway of resetting / rebooting the system to see if the problem goes away..
http://www.angrybeats.co.uk
Old Sep 19th, 2003, 06:40 PM
Local Time: 07:01 AM
United States View sjbartnik's Electric Blue & White 1st Gen MINI Cooper S Profile
You won't know what fault code was recorded until the dealer uses their scan tool to read the fault codes. There are many MANY different possibilities that can cause the light to come on. You can usually rest assured that if the engine is still running fine, it's probably something minor.
There is no way for you to reset it. There is logic built in so that if the fault that triggered the light is no longer detected (i.e. if it goes away on its own) then the light will eventually be turned off after a certain number of engine starts. The code however will remain in memory to be accessed by the dealer scan tool.
Sean Bartnik
2003 MINI Cooper S
Old Sep 19th, 2003, 08:44 PM
Actual Size's Avatar
Twi§ted Roads
Wake Island View Actual Size's Chili Red & White 1st Gen MINI Cooper S Profile
One thing to check is to make sure your gas cap is seated properly. I had the light come on in our Subaru 2.5RS and removing the cap then returning it has solved the problem.
Old Sep 20th, 2003, 09:02 AM
Thanks, I did notice that the dipstick wasnt seated correctly, would that cause a problem...?
I suppose i might go off before I go to the dealer...
Cheers,
Mick
Emission Light/ o2 sensors/Fault codes & Mots roland2003 First Generation Faults & Fixes 48 May 16th, 2010 05:07 PM
Emission light & mot shurm First Generation Faults & Fixes 0 Feb 12th, 2007 07:40 PM
warning light on - not another one! supa-dupa-cooper First Generation Faults & Fixes 4 Sep 7th, 2005 06:23 PM
Chrome Line Interior for Hazard Warning Light and Display Light Buttons matt1584 First Generation Interior & Ice 1 Mar 18th, 2005 08:18 PM
BBR 220 Conversion Emission Light problem waigor First Generation Faults & Fixes 2 Sep 1st, 2004 05:04 PM
