| I've been searching through the forums for a description of a small problem I have noted with my '03 MCS, but haven't found anyone else with the same issue: When I brake from moving slowly (still in 1st gear) there is an audible 'clunk' from the rear of the car, possibly the rear brakes themselves. There is no problem with the car slowing down. I only notice this when braking from moving slowly, although it may simply be that at higher speeds I can't hear the noise when I first apply the brakes. I'm aware of the ABS test the car does at 12MPH along with the auto-central locking, but this noise is occurring when I slow down rather than accelerate. Anyone else with a similar issue, or might know what is causing it? As it's not causing any problems, I was just going to mention it to the garage when it has it's first service, but I don't want to make a big issue about it if it isn't really a fault. |
| How loud is the noise? Can you tell if it is coming from one side or the other? You may want to try bouncing the rear corners while the car is stopped, to see if it is something loose that moves when the suspension travels. You may also want to pull off the wheels to look at the 2 caliper assemblies, possibly some shim fell off of one (or broke off), but if one looks like it has a piece that the other doesn't... Good luck in your diagnosis, keep us informed as to the cause if you ever find out. |
| The noise is about as loud as the ABS check done at 12MPH. It's more noticeable with the windows wound down. There is actually a similar noise from both sides of the back of the car (which is why I suspect the breaks), oddly enough each side doesn't 'sound' at the same time, I'll usually hear a clunk from one side first then a second later from the other. I'll try having a look around the back of the car this weekend and see if I can spot anything obvious, thanks for your suggestions. |
| I had this problem on a p reg fiesta. It was a tap that could be heard at slow speed in both forward and reverse. My garage changed the shoes under warrenty and this would solve the problem for about a week when it would come back. eventually they changed them agin and the problem stopped. My noise was from the front passenger side. I think it was due to poor fitting rather than a design fault. when are you shoes next due a change? |
I collected my cooper s on the 1st of september 03. After the first couple of days i noticed a matalic knocking noise coming from the back of the car at different speeds, anyway i took it back to my dealer and it turns out that it was the boot catch that was making the noise. They also said that if i had any more problems that i should also try the two rubber grommets on the boot door itself. As these can be wound in and out to adjust how the boot closes. Might be worth a check if you cant pinpoint the noise. |
| My wife has this problem on her Audi right now. I had it once before on my car. I think it is just the calipers sticking. They get all gunked up with brake dust and can stick. The clunk is the caliper braking free after being stuck for a moment. That is why you only hear it at low speeds when slowing gently. Aggresive braking from moderate to high speeds you will not hear this. A good way to eleviate this problem is get out and do some hard braking from good speed which will scrub off the buildup. 2004 MCS DS/B |
| I now think that this is the most probable cause of the noise I am hearing. I can't see any obvious problems at the back of the car (although I'm hardly a trained mechanic). The car doesn't do a great deal of miles, currently I've done 2400 and the car is 7 months old. The low use may also be contributing to the calipers sticking. I'll try a bit more hard breaking and see if this helps. If it is still continues to be a problem I'll mention it at the cars first service. |
| Rear Brakes | Lawrothegreat | First Generation Faults & Fixes | 1 | Feb 16th, 2007 08:52 PM |
| Rear Brakes | vanos | First Generation Faults & Fixes | 1 | Nov 10th, 2006 11:16 AM |
| clunk noise from rear caliper | wltklah | First Generation Faults & Fixes | 1 | Jul 8th, 2005 09:18 AM |
| Rear Brake "Clunk" MCS05 17inch Runflats | Mini 7 | First Generation Faults & Fixes | 3 | Feb 7th, 2005 01:10 AM |
| Rear brakes | vpr | Maintenance & MINI Care | 8 | Jun 5th, 2004 09:35 PM |
