| this is the way it works ... with the headlights on the first time you wash your windshield the lights also wash then its supposed to be every third time after that, however if you turn your lights off this resets the cycle and will do it the first time you use it again, also if you are on a long trip and squirt it at the start after some unknown distance it will reset again even if you have not used it (assumption is they are dirty after X number of miles regardless of using the squirters or not) |
| a combination of use and reading every post and thread posted on this here forum for the last year (ok so not every but I do read 98% excluding OT&B and reginal areas too far away from me) and remembering most of it |
| Fair enough Paul I had considered that it could be time not distance, but I figured the engineers would be smart enough to know that sitting idle in traffic for an hour wouldn't get very dirty but 500 miles (picking a number out of a hat) would reasonably assure a much greater chance of getting dirty .... oops over estimated engineers again ![]() |
| Yeah, stole the words outa my mouth Paul. There should be a new forum called "Stump G03" [Official rules and prizes pending]I'll volunteer as the first contestant: Dear G03, do you know whether the new dealer installed rear fog light kits rolling out in the US include independent toggles for the front and rear fogs? |
| Thats too easy ... yes ... the front fog switch is already there (if you have them they are in spot 4) rear fogs add the missing toggle in spot 5 (beware however if you order the switch bank the parts numbers from the scanned copy of the delae notification are erroneous) PS- I'm far from the most knowledgeable on these wonderful forums ... I'd say that would probably go to Paul M. |
| Ah-ha! Kind of a trick question: see this post on Bridger: http://www.bridger.us/mini/?Y=2003&M...witch#Comments Judges, can I have a ruling on this? PS: what is the color of the indicator lights on the front and rear toggles (it's a two-parter) |
| If that is true then why the need for a new switch at all?(the wiring to the switch would get changed not the switch itself?) And why is there a 'correct' part number being bandied about? (quotes because i've yet to see it so can not comment on if it is truely correct) As to your question are you refering to the indictor on the end of the metal switch itself? (green for front and again no rears in place yet so no comment) or the white LED against the orange plastic showing the fog light symbol?(located on the black plastic part of the toggle bank) |
| Yeah, it is confusing. My understanding is that you get a new bank (or 4) toggles (since the switches cannot be diddled with/replaced separately), in which the front fog toggle is now pre-wired to power the rear fogs. This is different from the UK toggle cluster (with 5 toggles), which has a separate toggle for the rear fogs. Rumor is that this difference is due to legal constraints in the US The UK toggles are lit at the tips: blue for fronts, orange for rears (look lovely, IMO). See pic here: http://gbmini.minisontop.com/blogger.html Kind of a dirty trick, that question was. Still think you da man, tho |
| you didn't specific UK toggles ... front fog toggle on US cars is definately green (mine is anyway) I'm taking a wait and see what part 993 is (thats whats being said is the correct one since 991 had a rear fog light toggle but the front fog light toggle was missing). I don't trust bridger (just my opinion), too many times they post before facts are known and then recant afterwards and over half their info comes from MINI2 first anyway (thankfully they do remember to give credit usually). |
| Headlamp Washer Blocked!! | Burgy | First Generation MINI Exterior | 9 | Feb 1st, 2006 11:17 PM |
| headlamp washer hell ! | randolph03 | First Generation MINI Exterior | 18 | Jun 16th, 2004 12:33 PM |
| Headlamp Bottle washer Pointless Question | ALD0 | General Discussion | 4 | Mar 13th, 2004 05:53 PM |
| Harmon Frequency Response | DCMINICOOPER | First Generation Interior & Ice | 5 | Oct 14th, 2003 08:44 PM |
| MINI frequency | Sejanus | General Discussion | 27 | Mar 20th, 2003 02:21 PM |
