Knock felt through steering wheel My S has 5k miles on the clock and has developed a new knock felt through the steering wheel, increasingly obvious through time. It is most easily reproduced by reversing braking then accelerating forward with some wellie and is felt just once when the power is taken up. This doesnt sound like the usual steering column problem recently reported. Has anyone any experience of this? Thanks for your help. |
| my steering was banging 2, they changed the steering column, the first time they said they were on back log for 5 weeks, goes to show how many MINIs r having this prob. Its happening again now, banging and on full lock i get a grinding noise, so its been booked in again to be looked at ![]() Try the search engine on this site, theres a few topics about this |
| If your window sticks up then get in the car, put the ignition on and then hold the electric window switch in the up position for 5 seconds. This will re-initialise the window and should hopefully sort out the problem. |
| yep my car's on it's 3rd steering column the orginal, the replacement and then the replacement for the replacment. Fingers crossed for 3rd time lucky. My 3rd was on order for about 4 weeks before it came in. |
| What I need to know is when the MINI is out of warranty will they start to charge you for another replacement rack . As uppy is on a 3rd rack and I am on my 2nd, whats to say in another year they may start to knock again Was MK1 Black MINI ONE (Sept 2001 Build) NOW NEW MX-5 |
| My 3rd one is now lumpy and their is a stange scratchy sound from the steering column think it's to do with the power sterring it seems to get louder by the day and the sounds, sounds strained when you turn the ignition off. I don't intend having my MCS outside the warranty period the cost's could be limitless. |
| 000Zero, did you get this sorted? I have this exact problem. Took MINI to the dealer on Monday, but "Sorry, I can't find anything wrong" was the reply. They had my car on a test drive and even put it up on ramps. put spanners to it, but couldn't find anything loose. I'm convinced that there is a problem, but cannot pin point what it is...and trying to convince the dealer is proving a nightmare! |
| weird knock sound when turning the steering wheel | mlt | First Generation Faults & Fixes | 12 | May 2nd, 2007 08:25 PM |
| steering column bearing click/knock | IDONEY | First Generation Faults & Fixes | 1 | Sep 19th, 2006 09:30 AM |
| Help please - Steering knock!!1 | tukansam | First Generation Faults & Fixes | 16 | Dec 7th, 2004 10:11 AM |
| Steering knock | daz31168 | First Generation Faults & Fixes | 17 | Feb 8th, 2004 12:34 PM |
| Steering knock | richl | First Generation Faults & Fixes | 1 | Apr 4th, 2003 08:43 PM |
