Cigarette lighter... - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Nov 24th, 2003, 03:59 PM
MiniMan7's Avatar
Let's Motor.
Send a message via MSN to MiniMan7
Local Time: 03:21 PM
Canada View MiniMan7's Electric Blue & White 1st Gen MINI Cooper S Profile
Unhappy Cigarette lighter...
Whenever I go to pull out my cigarette lighter (no I don't smoke ), it won't come out without a fight. I mean it almost rips out the whole system!!!
I have to hold the outside and pull it slowly otherwise it'll all come out in one big peice. Same when I plug my phone adapter in there. Any help?
Also, the ring around the lighter isn't lighting up at all? Is it supposed to?
-Adam
Old Nov 24th, 2003, 04:49 PM
obehave's Avatar
Mini Mod
Local Time: 02:21 PM
-Adam
They're a resistance fit with little fingers in the socket. You can either push the fingers in slightly, be careful, or try polishing the lighter (non flammable stuff). Also look to make sure nothing is misshapen.
Mine doesn't come out easily but if I twist it while removing it's simple enough. You have to remember that if it came out too easily it could launch a hot lighter out into your car.
Not good, and I speak from experience.
You mean lighting up when the headlights are on right? It should but I honestly don't remember if mine does or not.
Never used them when I smoked.
Old Nov 25th, 2003, 03:48 PM
The ring around the lighter does indeed illuminate.
Cigarette Lighter C11 XFF First Generation MINI Cooper S 2 Dec 20th, 2005 07:12 PM
Cigarette Lighter JS First Generation Interior & Ice 3 Oct 12th, 2005 10:05 PM
Cigarette Lighter duglia First Generation Interior & Ice 3 Aug 28th, 2005 09:21 PM
Cigarette Lighter duglia First Generation Faults & Fixes 2 Aug 26th, 2005 08:51 AM
cigarette lighter tcjohnsson First Generation Faults & Fixes 5 May 24th, 2002 07:35 PM
