| Do you turn your side lights off too ![]() Do you have day running lights? Don't know if they are linked to the dash illumination ... Do the dash lights turn off when you take the key out? |
| No they are not linked (at least the are not on US or UK spec MINI's) |
| Sounds like the BCU got a bit screwed. Try disconnecting the battery for a couple of minutes to drain the BCU memory the reconnect the batt. See if it's still doing it. Mind you if the dash illumination is staying on, the batt might have drained anyway. ![]() It was acceptable in the 80's |
| Our home microwave has a slightly similar problem ... sometimes the turntable does not turn any more. Disconnect power for a little time, then everything is fine again. Strange ... |
| Dashboard lights Have come on, Please help! | minibbb | First Generation Faults & Fixes | 9 | Aug 30th, 2006 08:39 AM |
| Dashboard lights | AndrewLondonUK | First Generation Faults & Fixes | 4 | Mar 26th, 2006 09:55 PM |
| 51 Mini 2 Dashboard Lights All Out | gerryu | First Generation Faults & Fixes | 1 | Jan 26th, 2006 12:58 PM |
| Dashboard Lights | tom999 | First Generation MINI Cooper | 3 | Feb 28th, 2005 11:30 AM |
| Dashboard lights | duncanbanana | First Generation Interior & Ice | 7 | Jun 12th, 2003 01:20 AM |
