| frozen window/ cold weather problems Yesterday we had alot of snow/ slush/ freezing rain & very cold temps (5- 20 degrees)...... today I was able to get my driver door open (& the window did drop a little like it should), but when I went thru the toll booth, my window would not go down...... once the car REALLY warmed up (30mins later) the window was fine...... & on Sat my b/f was driving & we heard his door whistling-- so we pulled over & he tried to open/ reclosed it, but he couldn't get the door open, finally after 5mins he was able to open the door. it seemed fine later on..... my question..... I know the cold weather can really affect the cars, but since this keeps happening to my driver door, should I call the dealer? or does someone have suggestions to keep this from happening? is this becoming a common problem for the MINIs? for now I guess i'll stock-up on de-icer spray (unless anyone else has a better idea) & plan on moving to a warmer climate..... Deana I like my men like I like my car: Euro! |
Sound advice DK! If u try & wind the window down in cold weather (hard frost/ice) it causes excess strain on the window motor & can then chew the cables in the window regulator. This will not be a warranty repair if this does happen! And its not cheap to fix either! I see this happen a lot on the BMW coupes & a lot on the MINI's. Dave |
| If its a new RR, then BMW had a hand i that too , funny though, Munich gets to -18 and below regularly, and nobody there complains. But its a dry cold, whereas here and USA coastal its damp, which causes the freeze ups I guess. |
| But it is on a fused circuit, either under the bonnet, or by the footwell, the fuse would surely give out before the motor packed in. , I will check with the techies if there is a "ceiling" on loads and get back, This sort of worries me. |
| frozen window | amandachannon | General Discussion | 2 | Apr 7th, 2005 12:56 AM |
| We need more cold weather in NE! | MetalMiniMayhem | New York & New England Region | 18 | Jan 19th, 2005 06:28 PM |
| 05 Boost Head Unit - Cold Weather Problems? | bc_seventy_six | First Generation Interior & Ice | 5 | Dec 21st, 2004 06:16 PM |
| Sat Nav Screen Cold Weather Problems | dietcokeplease | First Generation Interior & Ice | 1 | Feb 26th, 2004 11:42 AM |
| Cold, cold cold (frozen gearbox problem) | MINIHAHAHA | First Generation Faults & Fixes | 3 | Jan 21st, 2003 01:32 AM |
