IMPORTANT. Have you had a power steering pump failure? Please vote YES or NO!!! - Page 12 - MINI Cooper Forum - MINI2 Mini Cooper Forums
View Poll Results: IMPORTANT. Have you had a power steering/pump failure? YES or NO only please.
NO. I have *NOT* had a steering failure in my MINIs, 660 35.03%
YES. I have had *ONE* steering failure in my MINIs, 1,055 56.00%
YES. I have had *TWO* steering failures in my MINIs, 100 5.31%
YES. I have had *THREE* steering failures in my MINIs, 22 1.17%
YES. I have had *MORE THAN THREE* steering failures in my MINIs. 47 2.49%
Voters: 1884. You may not vote on this poll
LinkBack (28) Thread Tools Rating: Thread Rating: 15 votes, 4.20 average.
  1 links from elsewhere to this Post. Click to view. #166 (permalink)
Old Jan 24th, 2005, 12:35 PM
waynef's Avatar
Buy a Fabia vRS instead!
Local Time: 06:38 AM
England View waynef's Dark Silver & White 1st Gen MINI Cooper S Profile
Oh I forgot.
I forgot.
Name and shame your useless dealer.
Mine was Rydale Central BMW MINI in Birmingham.
Their management treated me like a ****: it's just a shame that they didn't on the same decent training courses as their good service stuff.
In fact, I am thinking of putting an entry on http://www.holymoly.co.uk/cc/ - just for them alone. *****.
Wayne
Faults: BK52MXM, BN53ZDZ
  #167 (permalink)
Old Jan 25th, 2005, 11:26 AM
randap's Avatar
Hangin at the Krusty Krab
United Kingdom Male View randap's Solid Black & Body Color 1st Gen MINI Cooper Profile View randap's Classified Ads
Quote: Originally Posted by randap
I had a pump failure in my first MINI along with a mid-shaft bearing failure. I have also had a mid-shaft bearing failure in my current MINI and the replacement looks like it is going the same way. Disappointing.....
UPDATE: Tommy2 has now been in 3 times for mid-shaft bearing problems. Replacement shaft was problematic from fitting. Dealer replaced steering rack (but not shaft), which did not fix the problem, so third visit was to replace the shaft and bearing (again).
Problem appears to be fixed (a different part number was fitted), but car has to go back in again on Thursday because they didn't align the steering properly (wheel is approx 10 degrees out when travelling in a straight line).
  #168 (permalink)
Old Jan 26th, 2005, 11:41 AM
johnlummis's Avatar
Send a message via AIM to johnlummis Send a message via Yahoo to johnlummis
Local Time: 07:38 AM
United Kingdom Male View johnlummis's Pure Silver & Body Color 1st Gen MINI Cooper Profile
Yes,i've had 1 power steering pump fail,water corroded the contacts.
NOTHING IN MODERATION,EVERYTHING TO EXCESS,MODERATION IS FOR MONKS AND I ONLY EAT RAW MEAT IF ITS WEARING RED STILLETTO'S
  #169 (permalink)
Old Feb 7th, 2005, 09:40 PM
My S went into the dealers today and the problem was described exactly by the service guy after I had told him that I had a steering rack problem, no second guessing on his part........... the car is 7 months and 4700 miles old.
New rack and pump has been ordered, and possibly back in a day or 2, maybe they are getting good at this swap out!!
A common issue around this is returning to the car after a 2 week layoff (as in mine), I wonder if there is a particular cause/effect?
I'd love to know how much this would cost when you are out of warranty!!! I may think again about my declaration of this one being a 'keeper'.
Are there any specific 'maintainance' tips surrounding this problem other than checking on the fluid regularly? I've become used to only checking the oil occasionally and topping up the washer bottles in cars!!!
  #170 (permalink)
Old Feb 7th, 2005, 09:49 PM
Shorty's Avatar
Send a message via Yahoo to Shorty
Local Time: 05:38 AM
England View Shorty's Solid Black & Black 1st Gen MINI Cooper S Convertible Profile
I'd like to keep mine too, but the thought of having to pay for my third steering column is making me think again
  #171 (permalink)
Old Feb 7th, 2005, 10:09 PM
Send a message via Yahoo to Alan Tois
Local Time: 01:38 AM
I don't think there's anything you can do "maintenance" wise. Maybe check the connector for corrosion once in a while. My '02 pump was replaced about a year and a half ago (I think), no problems so far. I was told that the harness was redesigned, which was replaced along with the pump for "corroded connectors". More than likely, the harness connectors were updated. But if the problem is continuing, may be just a bad pump design. I'm out of warranty now at 59,000 miles, so I hope nothing happens.
/al
  #172 (permalink)
Old Feb 7th, 2005, 11:37 PM
waynef's Avatar
...and that is the conclusion that I came too as well. I just knew with my luck that MCS's would hit the headlines with this "common" fault and I'd be left with an expensive albatross. Gladly so far I am wrong.
Good luck with deciding your next car.
Wayne
  #173 (permalink)
Old Feb 13th, 2005, 09:43 PM
United Kingdom View waigor's Dark Silver & Black 1st Gen MINI Cooper S Profile
Angry
Wow just been reading on the problems MC/S owners have had with their power steering and it scares the hell out of me. I should be in Cardiff with my GF for valentines but am instead here investigating this problem. To cut a long story short my p/steering went just before setting off on our journey this evening. Did a U turn, all was fine then waited for misses to leave the house then loaded the car.
Commenced our journey and steering was heavier than normal (like my first car the 89 AX), drove for 2 miles and it progressively got worse. Decided to drive into a petrol station near by and called mini assist. Engineer checked fluid and belt all was fine and concluded that it's a pump issue.
Car now going into garage 2morrow. Glad in a way that this happened in London, would hate to think what would have happened on the motorway doing over 70 on a bendy stretch.
  #174 (permalink)
Old Feb 15th, 2005, 05:23 PM
The dealers were great and fixed the car in a couple of days. When I picked it up the cost was £750 Plus VAT, and the bits were at cost as it was a warranty job, so I guess it would come in at around £1200 when it is out of warranty.OUCH!!!!!!
Wonder if you'd be covered on an extended warranty?
  #175 (permalink)
Old Feb 15th, 2005, 11:14 PM
waynef's Avatar
Eh? Lets get this straight. You were paying for warranty work? That is so wrong.
Wayne
  #176 (permalink)
Old Feb 16th, 2005, 06:07 AM
RVW's Avatar
RVW
003 On a Mission
United Kingdom Male View RVW's Hot Chocolate & Silver 2nd Gen MINI Cooper Diesel Clubman Profile View RVW's Classified Ads
You should name a shame this dealer / con-man
Any UK vehicle less than 3yrs old is covered by manufactures warranty and consequently any repairs of this nature should be done FREE= no money changes hands
I would send details and a copy of your invoice to MINI UK a complain vigorously.
  #177 (permalink)
Old Feb 16th, 2005, 06:28 AM
scooperman_uk's Avatar
almost 59k
United Kingdom View scooperman_uk's Solid Black & Body Color 1st Gen MINI Cooper S Profile
warranty work charged at cost... shocking...
i would hope that extended warranty would cover most things. otherwise whats the point of it?
  #178 (permalink)
Old Feb 16th, 2005, 03:16 PM
Local Time: 12:38 AM
View minimc's Classified Ads
Maybe I read this wrong, but I thought he was quoting costs from the dealer invoice which he would've had to pay, were his car not under warranty.
  #179 (permalink)
Old Feb 16th, 2005, 08:12 PM
Whoaa Boys!!!!!
The work was done FOR FREE UNDER WARRANTY, no complaints, sorry for sending a hare running there!!!.
The costs outlined are what it would cost when the car is out of the warranty and you have to pick the tab up yourself.
I was curious and quizzed the service guy out of interest, if as so many of us seem to quite like these little fellas, and decide to run them beyond the 3 years and this turns into one of their 'little foibles' that has to be lived with, just how hard would it hit our pockets.
If the pump, (I am tending to think it may well be this that is the weak link in the system), proves to be a problem long term, I wonder if a 3rd party upgrade may appear to assist the long termers, if the issue isn't completely erradicated by BMW. I couldn't extract out of the service guy whether the bits are straight replacements, or an on demand/as required retrofit upgrade.
  #180 (permalink)
Old Feb 16th, 2005, 08:15 PM
RVW's Avatar
RVW
003 On a Mission
[quote=mcsdsb]Whoaa Boys!!!!!
Well HUSH my MOUTH
Tags: , , , ,
LinkBacks (?)
LinkBack to this Thread: http://www.mini2.com/forum/first-generation-faults-fixes/49527-important-have-you-had-power-steering-pump-failure-please-vote-yes-no.html
Posted By For Type Date
MINI COOPER :: North American Motoring - Spontaneous engine bay fires! This thread Refback Apr 4th, 2009 12:07 AM
Volvo Performance Parts, Volvo Tamd70C, Volvo 240 Radio Wiring - Pandadog This thread Refback Mar 14th, 2009 08:47 AM
New Electric Sports Car, Pacific Electric Red Car, Used Electric Car Lift - Arcmirror This thread Refback Mar 11th, 2009 02:49 PM
Buy A Used Car Online Auto Cheap Insurance, Buy Cheap Car Insurance Now, Buy Car Used Car Cheap Insurance - Tempiichampion This thread Refback Mar 10th, 2009 02:56 PM
Bmw Radiator, Replacement Motorcycle Radiators, 1927 Ford Radiator - Wirerings This thread Refback Mar 10th, 2009 12:53 PM
Carefreerecovery Blog Archive Electric Mini Cooper, Electric Kit Cars, Electric Model Cars This thread Refback Mar 8th, 2009 05:28 PM
Car Insurance Low Price Uk, Car Insurance List Insurence Uk, Car Insurance Low Rate Uk - Billsquires This thread Refback Mar 8th, 2009 03:27 PM
Oberthur Cosmo Dual 72K Card, Obd Detector Need For 1994 Buick Park Avenue, Obrain Credit Header Info Online - Ethosgas This thread Refback Mar 8th, 2009 12:36 PM
MINI-FORUM - Ohjaustehostin vinkuu? This thread Refback Mar 2nd, 2009 10:09 AM
MINI-FORUM - Viimeisimmät viestit This thread Refback Feb 27th, 2009 06:42 AM
MINI-FORUM - Ohjaustehostin vinkuu? This thread Refback Feb 26th, 2009 07:51 PM
How many liters of CHF - 11S do i need to change or flush 05 Mini Cooper S power steering? - Yahoo! Answers This thread Refback Feb 25th, 2009 10:02 PM
Bekijk topic - Stuurbekrachtiging hapert This thread Refback Feb 19th, 2009 10:03 AM
Job cuts remain hot news, but MINI is “Best of British” | theSwitchback This thread Pingback Feb 19th, 2009 08:35 AM
Bekijk topic - Stuurbekrachtiging hapert This thread Refback Feb 19th, 2009 05:10 AM
Bekijk topic - Stuurbekrachtiging hapert This thread Refback Feb 18th, 2009 07:45 PM
MINI Power Steering Pump Failure? Yes or No - Page 3 - Mini Torque This thread Pingback Feb 17th, 2009 11:03 PM
Mini Cooper electric power steering pump - anyone else done it? This thread Refback Feb 17th, 2009 01:19 AM
MINI-FORUM - Ohjaustehostin vinkuu? This thread Refback Feb 3rd, 2009 09:52 PM
Mini one Power steering problem? - Yahoo! Answers This thread Refback Jan 26th, 2009 03:58 PM
MINI-FORUM - Ohjaustehostin vinkuu? This thread Refback Jan 13th, 2009 05:04 AM
Mini one Power steering problem? - Yahoo! Answers This thread Refback Jan 10th, 2009 04:28 AM
Mini (BMW) Service cost - boards.ie This thread Refback Jan 7th, 2009 05:02 PM
MINI COOPER :: North American Motoring - Spontaneous Engine Bay Fires! This thread Refback Dec 29th, 2008 04:33 PM
Mini (BMW) Service cost - boards.ie This thread Refback Dec 14th, 2008 01:19 PM
Mini (BMW) Service cost - boards.ie This thread Refback Dec 11th, 2008 07:09 PM
FAULTS AND FIXES on MINI2 - Fuel For Your MINI Obsession - MINI Cooper - S - One - Diesel - Works - Cabrio | BoardReader This thread Refback Nov 19th, 2008 10:20 AM
…now, how did I get here?… » Blog Archive » common mini failure This thread Pingback Mar 4th, 2007 11:40 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
possible power steering pump failure Woolly44 First Generation Faults & Fixes 1 Jun 7th, 2010 06:33 PM
Power steering pump with failure masha First Generation Faults & Fixes 4 Apr 24th, 2009 08:46 PM
Power Steering Pump failure on Cooper trevtot First Generation Faults & Fixes 12 Jul 28th, 2008 11:53 AM
2006 Cooper - CVT Auto Transmission Failure #2 & Power Steering Pump Failure - Why??? Joe Z First Generation Faults & Fixes 17 Feb 18th, 2006 12:33 AM
