| View Poll Results: IMPORTANT. Have you had a power steering/pump failure? YES or NO only please. | |||
| NO. I have *NOT* had a steering failure in my MINIs, | | 652 | 35.78% |
| YES. I have had *ONE* steering failure in my MINIs, | | 1,008 | 55.32% |
| YES. I have had *TWO* steering failures in my MINIs, | | 95 | 5.21% |
| YES. I have had *THREE* steering failures in my MINIs, | | 21 | 1.15% |
| YES. I have had *MORE THAN THREE* steering failures in my MINIs. | | 46 | 2.52% |
| Voters: 1822. You may not vote on this poll | |||
| | LinkBack (28) | Thread Tools | Rating: |
| Agreed Paul, Thats entirely the reason why I made the title as vibrant as it could be with the word "IMPORTANT" and "Please vote YES or NO" because I understand that simple fact regarding apathy. Hence the reason also why I am going onto as many of the other steering related threads on here trying to drum up support for this poll. This poll is just that after all, without a fair chance though, no one can say and BMW can successfully continue to pull the wool over our collective eyes. I'd really appreciate you making it "Sticky", then things would be more objective. Pretty please. Thanks again for agreeing with my original thoughts. |
| Unfortunately only BMW has the real stats. Goonery may have an insight but I would not expect him to divulge much. Maybe keeping an eye on what the US NHTSA publishes will be worthwhile. in the meantime I will keep an eye on my own pump system |
| I've already posted twice on this matter and the only thing that doses worry me is my scenario. I've decided on Monday, totally unworried, that maybe possibly my steering is a bit noiser than I thought it should be and I happened to be passing the dealership that I bought it from. There was no failure or anything from steering, it was ok. So I go in and they say that it doesn't sound right, they need to take a closer look, so it's booked in for the wednesday. Not the Tuesday because they have to order some spare parts. Fair enough, mini goes in wednesday, come later on Weds they ring me to say the car won't be available as they haven't completed the work, as they have had to change the complete steering rack and power steering associated componenents. Now this leads me to think, that if on monday they saw what appeared to me to be a fairly minor problem that turned out to be a major problem, That they ordered the whole rack and power steering parts in to eventually resolve the problem, it does sort of smell of an issue they were already aware about. This is sounds fairly negative, but it could noy have been a more pleasurable experience as far as dealers go. They collected the car and delivered it back to the house. I asked for a bit of internal trim to be replaced. On the C post where the little picture of the rear seat belt is and the rear seat belt feeds through, I had put a scratch in it with the dogs cage. The bit of trim cost 14.52 GBP, 52.86GBP to fit!!!!!!! That's reasonable!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!! |
| The thing that worries me is the fact there is a cooling fan on the underside for cooling the pump. To me this is an indication of a weakness that has a bandaid applied in the form of the fan. Add to that the design change that moves the breaker for the rad fans off the pump fan circuit. The whole setup gives me something to keep an eye on in the realm of long term use and reliability. But then, I own a 3rd gen RX-7, compared to the worries of that beast I consider the MCS worry free. |
| I have to add to this, as soon as I got her back I had to give her a good spanking, rip roaring thrash around the lanes of Kent and Surrey just to test my new steering out. And she didn't disappoint, but there again I never fell out of love in the first place!!!!!! Still and always will be so much Funnnnnnnnnnn With a Capital FFFFFFFFFFFF!!!!!!!!!! |
Goonery Goonery has already commented briefly on this matter. He is though, by his own admission, not privvy to the complete information loop within BMW/MINI and can only comment from his knowledge during the manufacturing process. He did say though sometime ago that he knew of a bad batch of pumps back in September 2002, that would explain my first MINI's first failure. It doesn't however explain it's second failure in March 2003, or my brand-new September 2003 build MINI, that failed in December 2003. Form your own opinion, but I feel (and it's being slowly backed up by others opinions too like aharte here), that something smells a more than a little off here. One might say "ratty" even? |
| Something isn't right here. It is very unlikely that anyone will end up with three bad pumps in a row. Can those with mulitple failures contact each other and compare notes on driving style, usual ambient temps and how much stop and go traffic is done? Also I assume that all have made sure the cooling fan on the underside is operating. Beyond that I wonder about debris in the pump oil. If the dealer does not flush the system when changing pumps you will probably trash every pump put on. |
| MINI #1: BK52MXM Failure #1: Car parked on my drive in a slightly nose-down attitude for 8 hours. Started engine in morning and steering did not work. Recovered.MINI #2: ??53??? Failure #3: 1 month old car left on my mothers totally flat drive, while I go on a holiday of a lifetime in Australia. I return back, jet-lagged, 4 weeks later. I get into the car and start it, and the steering did not work. Recovered.Does that help? I am not at all sure that there's any pattern matey. Only that BMW offer us all a lot of flannel. Last edited by waynef; Feb 13th, 2004 at 10:30 PM. Reason: 4 weeks instead of 2 |
| I'm still interested, but I've looked at stats from worldwide sales and cannot find any pattern that points to a particular problem with PAS pumps across vehicles built since 2001, this takes into account all climates and many different driving conditions, nearly 500,000 cars built now and nothing to point at PAS pumps as being a major weakness. Not saying that you are wrong , but coincidence could be a factor. frankly I'm puzzled. Have you still got the car?. |
| Tags: failure, fault, power steering, pump failure, steering pump |
LinkBacks (?)
LinkBack to this Thread: http://www.mini2.com/forum/first-generation-faults-fixes/49527-important-have-you-had-power-steering-pump-failure-please-vote-yes-no.html | ||||
| MINI COOPER :: North American Motoring - Spontaneous engine bay fires! | This thread | Refback | Apr 4th, 2009 12:07 AM | |
| Volvo Performance Parts, Volvo Tamd70C, Volvo 240 Radio Wiring - Pandadog | This thread | Refback | Mar 14th, 2009 08:47 AM | |
| New Electric Sports Car, Pacific Electric Red Car, Used Electric Car Lift - Arcmirror | This thread | Refback | Mar 11th, 2009 02:49 PM | |
| Buy A Used Car Online Auto Cheap Insurance, Buy Cheap Car Insurance Now, Buy Car Used Car Cheap Insurance - Tempiichampion | This thread | Refback | Mar 10th, 2009 02:56 PM | |
| Bmw Radiator, Replacement Motorcycle Radiators, 1927 Ford Radiator - Wirerings | This thread | Refback | Mar 10th, 2009 12:53 PM | |
| Carefreerecovery Blog Archive Electric Mini Cooper, Electric Kit Cars, Electric Model Cars | This thread | Refback | Mar 8th, 2009 05:28 PM | |
| Car Insurance Low Price Uk, Car Insurance List Insurence Uk, Car Insurance Low Rate Uk - Billsquires | This thread | Refback | Mar 8th, 2009 03:27 PM | |
| Oberthur Cosmo Dual 72K Card, Obd Detector Need For 1994 Buick Park Avenue, Obrain Credit Header Info Online - Ethosgas | This thread | Refback | Mar 8th, 2009 12:36 PM | |
| MINI-FORUM - Ohjaustehostin vinkuu? | This thread | Refback | Mar 2nd, 2009 10:09 AM | |
| MINI-FORUM - Viimeisimmät viestit | This thread | Refback | Feb 27th, 2009 06:42 AM | |
| MINI-FORUM - Ohjaustehostin vinkuu? | This thread | Refback | Feb 26th, 2009 07:51 PM | |
| How many liters of CHF - 11S do i need to change or flush 05 Mini Cooper S power steering? - Yahoo! Answers | This thread | Refback | Feb 25th, 2009 10:02 PM | |
| Bekijk topic - Stuurbekrachtiging hapert | This thread | Refback | Feb 19th, 2009 10:03 AM | |
| Job cuts remain hot news, but MINI is “Best of British” | theSwitchback | This thread | Pingback | Feb 19th, 2009 08:35 AM | |
| Bekijk topic - Stuurbekrachtiging hapert | This thread | Refback | Feb 19th, 2009 05:10 AM | |
| Bekijk topic - Stuurbekrachtiging hapert | This thread | Refback | Feb 18th, 2009 07:45 PM | |
| MINI Power Steering Pump Failure? Yes or No - Page 3 - Mini Torque | This thread | Pingback | Feb 17th, 2009 11:03 PM | |
| Mini Cooper electric power steering pump - anyone else done it? | This thread | Refback | Feb 17th, 2009 01:19 AM | |
| MINI-FORUM - Ohjaustehostin vinkuu? | This thread | Refback | Feb 3rd, 2009 09:52 PM | |
| Mini one Power steering problem? - Yahoo! Answers | This thread | Refback | Jan 26th, 2009 03:58 PM | |
| MINI-FORUM - Ohjaustehostin vinkuu? | This thread | Refback | Jan 13th, 2009 05:04 AM | |
| Mini one Power steering problem? - Yahoo! Answers | This thread | Refback | Jan 10th, 2009 04:28 AM | |
| Mini (BMW) Service cost - boards.ie | This thread | Refback | Jan 7th, 2009 05:02 PM | |
| MINI COOPER :: North American Motoring - Spontaneous Engine Bay Fires! | This thread | Refback | Dec 29th, 2008 04:33 PM | |
| Mini (BMW) Service cost - boards.ie | This thread | Refback | Dec 14th, 2008 01:19 PM | |
| Mini (BMW) Service cost - boards.ie | This thread | Refback | Dec 11th, 2008 07:09 PM | |
| FAULTS AND FIXES on MINI2 - Fuel For Your MINI Obsession - MINI Cooper - S - One - Diesel - Works - Cabrio | BoardReader | This thread | Refback | Nov 19th, 2008 10:20 AM | |
| …now, how did I get here?… » Blog Archive » common mini failure | This thread | Pingback | Mar 4th, 2007 11:40 PM | |
| Currently Active Users Viewing This Thread: 3 (0 members and 3 guests) | |
| possible power steering pump failure | Woolly44 | First Generation Faults & Fixes | 1 | Jun 7th, 2010 06:33 PM |
| Power steering pump with failure | masha | First Generation Faults & Fixes | 4 | Apr 24th, 2009 08:46 PM |
| Power Steering Pump failure on Cooper | trevtot | First Generation Faults & Fixes | 12 | Jul 28th, 2008 11:53 AM |
| 2006 Cooper - CVT Auto Transmission Failure #2 & Power Steering Pump Failure - Why??? | Joe Z | First Generation Faults & Fixes | 17 | Feb 18th, 2006 12:33 AM |
