| View Poll Results: IMPORTANT. Have you had a power steering/pump failure? YES or NO only please. | |||
| NO. I have *NOT* had a steering failure in my MINIs, | | 652 | 35.78% |
| YES. I have had *ONE* steering failure in my MINIs, | | 1,008 | 55.32% |
| YES. I have had *TWO* steering failures in my MINIs, | | 95 | 5.21% |
| YES. I have had *THREE* steering failures in my MINIs, | | 21 | 1.15% |
| YES. I have had *MORE THAN THREE* steering failures in my MINIs. | | 46 | 2.52% |
| Voters: 1822. You may not vote on this poll | |||
| | LinkBack (28) | Thread Tools | Rating: |
First the transmission, now the PSP I have a 2002 Mini Cooper, 58K miles, and the power steering pump failed yesterday, finally and completely, after working intermittently for a week. My mechanic has quoted $1200 to repair; he can't find a refurbished pump. I called the dealer to try to get some of this "goodwill" help others have gotten, and they referred me to Mini corporate. Left a message there, but I won't hold my breath, since they seem to have backed off of the goodwill stuff on the older models. I did file a complaint with the NHTSA, and I see there is a class action pending on this issue. Unlikely much will come of either of those things. I just wish I had sold the damn thing after I replaced the transmission last year. The transmission. On a manual transmission car with 55,000 miles on it. Good lord. I had no problems with this car for eight years, but it's really making up for lost time now. |
| No idea why you are being quoted $1200! (£800) The pump is available refurbished from BBA Reman (UK and USA) amongst others and is approx 1 hour labour job to replace at any good garage/auto-shop, many home mechanics even swap it diy not really a big job. More Details here: Power Steering Pump replacement - Forums |
| My MINI Cooper 2003 sometimes encountered steering heavy for around 30 seconds. After I pushing the accelerate faster a bit, then it back to normal. I only encountered the heavy steering once a while only, around 2-3 weeks once. Any idea? Does the power steering pump or anything need to change soon? :-( |
| Steering Faults Hi I'm not very good at navigating round these forums so I hope I've done this right ![]() I'm looking to buy a 51 reg mini later this week and have just discovered all this info on the steering faults :O I'm now really worried and it's putting me off. Will it always give a warning it's going e.g. become noisy? Does replacing the pump (is that what fixes it?) fix it for good or could it happen again? Should I be put off by this? The seller said it had a clunk on the steering which was being fixed ready for the MOT tomorrow which I didn't worry about until I read all this! Thanks for any help x |
| I know what you're saying - the bad issues spread faster than the good points ![]() I think I know people who could fix it at a reasonable price if it went, but I'm most worried about it just packing in while driving at speed round a bend / roundabout?! x |
| The steering does not fail completely, it just gets heavier to turn.........this can and does happen in any modern car with electric or hydraulic power assisted steering not just a Mini and is why it is not considered a safety recall. In the same way the servo power assistance on any modern cars brakes can fail........the brakes will still work they just become much harder to press which can catch you out. This is a price we pay for convenience over the simple old style cars of the past but at the end of the day anything mechanical or electrical can fail without warning and does not work for ever. The idea of MOT's and service/maintenance checks is to spot problems developing before they happen, so maybe have your Mini checked over before you buy by the RAC/AA or someone who knows about cars. |
| What is your fault? The steering column cannot affect your power steering unless you have a later Mk2 Mini 2007 onwards with fully electric power steering. The earlier Mini's can have a clicking/clunking steering column bearing but this is nothing to do with the pump. Despite the fault being obvious to a good mechanic BMW like most main dealers will charge you for a diagnostic investigation to confirm fault before doing the job. This is really just a further money making exercise but is impossible to avoid to get the free replacement! |
| Well I'm still planning on going ahead with it if everything checks out. Do you think it would be noticably not as nice to drive being an old 51 reg or should it be near as good as a newer one to drive? I am having it checked out before purchase and then a full service shortly after buying to make sure everthing is good with it but I'm expecting there to be some wear and effect due to the age. x |
| We have 02 reg and a 51 reg Mini both on around 50-60,000 miles and both drive near as good as new, but of course there will always be some wear and tear due to age and depending on how well it has been cared for by previous owners. |
| No Power Steering Pump Failure I have owned my mini since October, 2001 (it is a 2002 MCS) and I have not had a power steering pump failure. I don't know if the year/model info. helps, but there it is. |
| I love my mini - but this steering issue is a huge conern for me ! My car is now almost 7 years old - however I have owned and used older cars in the past and never has the PSP been a problem. What is the usual life of these pumps ? Is 7 years a reasonable life? |
| It should not be a huge concern......if it really worries you have the pump replaced, it is only a 2 hour job in any good garage to replace, the existing one may last for years or it could start failing tomorrow but you usually get an intermittent warning of occasional heavy steering usually while parking. We have 2 MINI's in the family, both 10 years old with 60,000 miles one had the pump replaced couple of years ago, the other is still going strong but has always had a louder whining noise! |
| Thanks for response. I am having it checked out next week. Power Steering did not function one day last week - but was back the following day!! As a result I am nervous driving long distances in it ! Ya gotta have faith in your car ! |
| Tags: failure, fault, power steering, pump failure, steering pump |
LinkBacks (?)
LinkBack to this Thread: http://www.mini2.com/forum/first-generation-faults-fixes/49527-important-have-you-had-power-steering-pump-failure-please-vote-yes-no.html | ||||
| MINI COOPER :: North American Motoring - Spontaneous engine bay fires! | This thread | Refback | Apr 4th, 2009 12:07 AM | |
| Volvo Performance Parts, Volvo Tamd70C, Volvo 240 Radio Wiring - Pandadog | This thread | Refback | Mar 14th, 2009 08:47 AM | |
| New Electric Sports Car, Pacific Electric Red Car, Used Electric Car Lift - Arcmirror | This thread | Refback | Mar 11th, 2009 02:49 PM | |
| Buy A Used Car Online Auto Cheap Insurance, Buy Cheap Car Insurance Now, Buy Car Used Car Cheap Insurance - Tempiichampion | This thread | Refback | Mar 10th, 2009 02:56 PM | |
| Bmw Radiator, Replacement Motorcycle Radiators, 1927 Ford Radiator - Wirerings | This thread | Refback | Mar 10th, 2009 12:53 PM | |
| Carefreerecovery Blog Archive Electric Mini Cooper, Electric Kit Cars, Electric Model Cars | This thread | Refback | Mar 8th, 2009 05:28 PM | |
| Car Insurance Low Price Uk, Car Insurance List Insurence Uk, Car Insurance Low Rate Uk - Billsquires | This thread | Refback | Mar 8th, 2009 03:27 PM | |
| Oberthur Cosmo Dual 72K Card, Obd Detector Need For 1994 Buick Park Avenue, Obrain Credit Header Info Online - Ethosgas | This thread | Refback | Mar 8th, 2009 12:36 PM | |
| MINI-FORUM - Ohjaustehostin vinkuu? | This thread | Refback | Mar 2nd, 2009 10:09 AM | |
| MINI-FORUM - Viimeisimmät viestit | This thread | Refback | Feb 27th, 2009 06:42 AM | |
| MINI-FORUM - Ohjaustehostin vinkuu? | This thread | Refback | Feb 26th, 2009 07:51 PM | |
| How many liters of CHF - 11S do i need to change or flush 05 Mini Cooper S power steering? - Yahoo! Answers | This thread | Refback | Feb 25th, 2009 10:02 PM | |
| Bekijk topic - Stuurbekrachtiging hapert | This thread | Refback | Feb 19th, 2009 10:03 AM | |
| Job cuts remain hot news, but MINI is “Best of British” | theSwitchback | This thread | Pingback | Feb 19th, 2009 08:35 AM | |
| Bekijk topic - Stuurbekrachtiging hapert | This thread | Refback | Feb 19th, 2009 05:10 AM | |
| Bekijk topic - Stuurbekrachtiging hapert | This thread | Refback | Feb 18th, 2009 07:45 PM | |
| MINI Power Steering Pump Failure? Yes or No - Page 3 - Mini Torque | This thread | Pingback | Feb 17th, 2009 11:03 PM | |
| Mini Cooper electric power steering pump - anyone else done it? | This thread | Refback | Feb 17th, 2009 01:19 AM | |
| MINI-FORUM - Ohjaustehostin vinkuu? | This thread | Refback | Feb 3rd, 2009 09:52 PM | |
| Mini one Power steering problem? - Yahoo! Answers | This thread | Refback | Jan 26th, 2009 03:58 PM | |
| MINI-FORUM - Ohjaustehostin vinkuu? | This thread | Refback | Jan 13th, 2009 05:04 AM | |
| Mini one Power steering problem? - Yahoo! Answers | This thread | Refback | Jan 10th, 2009 04:28 AM | |
| Mini (BMW) Service cost - boards.ie | This thread | Refback | Jan 7th, 2009 05:02 PM | |
| MINI COOPER :: North American Motoring - Spontaneous Engine Bay Fires! | This thread | Refback | Dec 29th, 2008 04:33 PM | |
| Mini (BMW) Service cost - boards.ie | This thread | Refback | Dec 14th, 2008 01:19 PM | |
| Mini (BMW) Service cost - boards.ie | This thread | Refback | Dec 11th, 2008 07:09 PM | |
| FAULTS AND FIXES on MINI2 - Fuel For Your MINI Obsession - MINI Cooper - S - One - Diesel - Works - Cabrio | BoardReader | This thread | Refback | Nov 19th, 2008 10:20 AM | |
| …now, how did I get here?… » Blog Archive » common mini failure | This thread | Pingback | Mar 4th, 2007 11:40 PM | |
| Currently Active Users Viewing This Thread: 3 (0 members and 3 guests) | |
| possible power steering pump failure | Woolly44 | First Generation Faults & Fixes | 1 | Jun 7th, 2010 06:33 PM |
| Power steering pump with failure | masha | First Generation Faults & Fixes | 4 | Apr 24th, 2009 08:46 PM |
| Power Steering Pump failure on Cooper | trevtot | First Generation Faults & Fixes | 12 | Jul 28th, 2008 11:53 AM |
| 2006 Cooper - CVT Auto Transmission Failure #2 & Power Steering Pump Failure - Why??? | Joe Z | First Generation Faults & Fixes | 17 | Feb 18th, 2006 12:33 AM |
