| Same topic, different car. My brother had the same problem, it had happened 3-4 times. He was told to make sure the gas cap was screwed on as tight as possible. If tightening didn’t work, the only other thing they could do was to pressure check the fuel system and look for leaks. Intelligence is not a requirement for existence. There are two types of people, explosive and , implosive: An explosive personality is the user who yells at the administrator when his computer stops working. An implosive personality is the administrator who takes the abuse day in and day out, then snaps suddenly and shoots everyone in the office. Current Vehicles: 96 Ford Ranger 96 Dodge Status NEW Vehicle: 99 M3 |
| Thanks for the replies! I always make sure the cap is fully tighten after a gas stop... My dealer changed the gas cap three times but it didn't solve the problem. I took an appointment later today to make them check for the ecu fault codes, but I'm sure it's still a loose gas cap problem... Has anyone had the same problem (more than 5 Check Engine for a loose cap)? If so, how did your dealer fixed it? (I guess I'll have to tell my dealer how to fix this since they can't...) Thank you for any help! Keep motoring (with my new cruising friend : the Check Engine) 2012 Countryman S All4 - Light White, Sunroof, Premium & Cold packages, Xenons, Adaptive lights, and lots of fun!! |
| have them pressure test the system, sounds like its leaking somewhere and I'd say the gas cap is very unlikely to be the issue with so many new ones tried. I've never had the light go on and I don't crank my cap shut, just a nice turn until I feel it click in. |
| I haven't had a problem with the check engine light going on for a loose gas cap, but I have had a "Check Filler Cap" light come on because I didn't have the cap tight when I got gas once. I have a February 2003 MCS build with Navigation. This idiot light is next to the seatbelt light on the display. Do non-NAV MINI's have the "check filler cap" light like mine? Just curious... MCS, DS/B, All Options and JCW! |
| As RickB says the check filler cap light will only light if the system sensor's a leak (presure loss) ie the filler/gas cap is loose. just because the light says "check filler cap" does not mean to say the cap is at fault! You need to get ypur car back to the dealers because there is a leak somewhere in the system they need to be looking at all the seals, pipes, connectors etc in the system not just changing filler caps hope this helps Stu |
| Thank you Studboy! I decided to change dealer for the next service ( which is next Monday!) The advisor told me they would look at the whole fuel system for a leak... Hopefully they'll find it! 2012 Countryman S All4 - Light White, Sunroof, Premium & Cold packages, Xenons, Adaptive lights, and lots of fun!! |
| Help? Gas Cap Conversion Kit...is it the new or old style gas cap? | NeedMiniInfo | First Generation MINI Exterior | 0 | Aug 14th, 2007 10:16 AM |
| Check Engine, ABS, and Tire Pressure light--All at the same time! | pnksugr21 | First Generation Faults & Fixes | 2 | Jul 12th, 2006 12:37 AM |
| check gas cap--problem | fillnflash | General Discussion | 4 | Oct 14th, 2004 08:51 PM |
| loose handbrake cap | iabbott | First Generation Faults & Fixes | 8 | Jun 8th, 2002 03:37 PM |
