| window washer water reservoir empty In fact I was really shocked to find out that there is no warning (or whatsoever) on a empty water reservoir. (or did I miss something ?) very "Works". |
| I noticed that if I carefully top up the washer reservoir to the brim, then after driving the car, the level always went down quite a way without using any washers. It wasn't leaking out the bottom anywhere overnight if just left alone, only when you drive the car did the water disappear. If you carefully look inside the interior of the wing panel, you will see that the washer bottle is a very peculiar shape, the top of which extends some way into the panel space and level with the neck. This means that the top level of the neck is not higher than the rest of the top level of the bottle (as it is in most cars) so as soon as you go down a hill, water just spills out the next past the blue cap and the level goes down. Chips |
| Rear washer not spraying water | MINICSBRG | First Generation Faults & Fixes | 1 | Dec 20th, 2006 02:27 PM |
| Washer reservoir dumps straight onto road | BoySpring | First Generation Faults & Fixes | 1 | Aug 22nd, 2006 06:52 PM |
| HID washer water hose | dinlo | First Generation Faults & Fixes | 1 | Apr 12th, 2003 09:11 PM |
| Windshield Washer Fluid Reservoir | LockjawDavis | First Generation Faults & Fixes | 8 | Feb 20th, 2003 05:32 PM |
| Larger Windscreen Washer Fluid Reservoir??? | GMINI | First Generation Faults & Fixes | 2 | Jan 31st, 2003 08:37 PM |
